rear arm of c5 mk1
notinserviceuk
x 5
rear arm of c5 mk1
Unread post by notinserviceuk »
hi
i am trying to work out if the item number 13 product code 5166 65 rear susipion rebounb block would cause a slight pop noise if wore out i have replaced number 14 rebound block any ideas diagram and picture added
ty
x 8132
Re: rear arm of c5 mk1
I should think it may do! :)
x 1994
Unread post by Stickyfinger »
More a "Thud".....
What are you driving over when you hear this "Pop"
The rear bearings are well known for making a noise when going at slow speeds over speed humps etc......this is a known symptom that the rear bearings need replacing. This cannot be checked with the car on the ground as it is under tension.
notinserviceuk
x 5
wheel bearings brand new so i going to order some rebound blocks then modifed them to fit and put pics up were i can
thanks all
PaulC5
x 696
Unread post by PaulC5 »
I think Stickyfinger might be referring to the arm bearings, possibly part 7 in the diagram and not the wheel bearings.
notinserviceuk
x 5
could be but in the diagram i referring to no 13
x 1994
PaulC5 wrote: 24 Nov 2025, 21:36 I think Stickyfinger might be referring to the arm bearings, possibly part 7 in the diagram and not the wheel bearings.
I am..........
viewtopic.php?p=741470&hilit=C5+rear+ar ... gs#p741470
