XANTIA HDi RUNNING ROUGH
Rhothgar
(Donor 2026)
x 221
Re: XANTIA HDi RUNNING ROUGH
Unread post by Rhothgar »
Huskyxantia wrote: 15 Nov 2025, 09:47 Seems your getting somewhere , even though its like stabbing in the dark,ive subscribed to this post I'm keen to find out what happens.
Those of us still with Xantia HDi (and other models) should perhaps be doing reference videos of their cars in a working state ie dash lights pre start-up and on start-up to create a reference of what we should be seeing.
The V4020 red light comes on mine on startup and I am not sure it should. That is the coolant temp light. Of course, some of us may have Exclusive models with more gauges.
I think it would just be really useful so we can support each other and know what the baseline is for a correctly operating car.
Skull
(Donor 2026)
x 382
Unread post by Skull »
Rhothgar wrote: 15 Nov 2025, 10:34
Rothgar
Good idea but too late for me :oops:
Rhothgar wrote: 15 Nov 2025, 10:34 The V4020 red light comes on mine on startup and I am not sure it should. That is the coolant temp light.
Rothgar
It is supposed to come on with ignition check lights and extinguish when started according to the handbook. Flashing STOP warning and red light indicates low coolant (plus overheating if temperature gauge is also high).
Gary
Skull
(Donor 2026)
x 382
Me too 8-[
Gary
Skull
(Donor 2026)
x 382
Well the Camshaft Sprocket and Hub have been removed today.
Skull's - Removed for Woodruff Key Inspection
Skull's - Rear of Camshaft Sprocket & Hub
^ The 'Woodruff Key' but not as we know it Jim (more of locating lug) intact. Looks to be all one piece to my naked eye, but on the photos looks seperate - tight at least and undamaged. ?
Skull's - Camshaft slot for lug
Camshaft slot to allow correct position of Hub.
Interestingly but unrelated to the current problem, looking at the various red paint marks on the engine and sprockets, at least the Cam Sproket has been off the Hub before I got the car (in 2015) as if I rotate the sproket 1 bolt hole I believe it will line up with the red dot on the cam cover on assembly. I never used those marks when I done my belt change in 2021.
Camshaft Top Cover will be the next area to inspect ....
Gary
Huskyxantia
x 921
Unread post by Huskyxantia »
Sorry for asking this , if its already been done (sorry) is the head gasket ok ?
:-D
Skull
(Donor 2026)
x 382
Nothing to indicate it's Head Gasket related yet ....
Gary
x 8422
At least we know the cam sprocket is intact and correctly timed Gary... The plot thickens...
Huskyxantia
x 921
Worth checking and you get to see the oil seal condition too.
:-D
Huskyxantia
x 921
Middle photos of the sprocket it has scrape marks on 2 sections, could it be possible that its been touching somewhere ,,then moving backwards the shaft itself is or has that been hit or warped ever so slightly? Just a niggle , hope I'm wrong
:-D
Rhothgar
(Donor 2026)
x 221
Huskyxantia wrote: 16 Nov 2025, 07:17 Middle photos of the sprocket it has scrape marks on 2 sections, could it be possible that its been touching somewhere ,,then moving backwards the shaft itself is or has that been hit or warped ever so slightly? Just a niggle , hope I'm wrong
Good spot but that's historic I would imagine. It would surely be shiny if caught recently. Worth a closer inspection though for sure.
Skull
(Donor 2026)
x 382
Yes I saw that and just thought it was very minor rubbing at some stage from either the cam cover nose or the engine lip. [EDIT] That’s the Cam Position Sensor (cam cover ‘nose’)
Skull’s - Cam Hub partially removed
I’m not concerned about it though HuskyXantia - I have bigger problems …
Gary
Skull
(Donor 2026)
x 382
Rhothgar wrote: 16 Nov 2025, 09:42 Good spot but that's historic I would imagine. It would surely be shiny if caught recently. Worth a closer inspection though for sure.
Maybe that’s why the Cam Sprocket was rotated, that would explain why the old ‘red’ timing marks prior to my ownership were out of line - possibly, as mentioned above it has been off for some reason.
Gary
Skull
(Donor 2026)
x 382
Rothgar sent me some pages from his Citroen Diagnosis Manual....
Am I enterpreting this right in that the ECU may not or does not remember these faults :?:
Jim thought as there was no temporary fault listed for the Fuel Pressure Sensor that my theory about the coolant shorting the connector out was wrong.
Where / How do you get the Fault Code 14 from then?
Rothgar's - FAULT DIAGNOSIS
^Sorry about the size of this ^
Gary
Huskyxantia
x 921
Skull wrote: 16 Nov 2025, 09:54 Yes I saw that and just thought it was very minor rubbing at some stage from either the cam cover nose or the engine lip.Image
That's good at least its nothing thats causing it then, another one ticked off your list.
:-D
Rhothgar
(Donor 2026)
x 221
Skull wrote: 16 Nov 2025, 10:48 Rothgar sent me some pages from his Citroen Diagnosis Manual....
Do you not get them from here:-
or perhaps they are Elit or Proxia codes? Jim may well know.
Yes. You are interpreting it right. The ECU may not memorise a code. Don't ask me how. Maybe if there is no communication with the ECU at time of event would result in no code being stored. So my question would then be where else are they stored if not in the ECU? Very probably a chip in the dash perhaps?
