Changing C5 rear suspension ram boot - can't get piston retracted
Oliver53
System depressurised with Lexia (during the process I heard actuating of valves, and suspension movement). Still the piston doesn't retract with a lever. It feels there's pressure in it. Any ideas please?
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
1985 2CV6 Special
Kees
- x 148
Re: Changing C5 rear suspension ram boot - can't get piston retracted
If the car is still on the ground, sometimes you have to make contact again and then switch off.
Oliver53
What I did:Kees wrote: 11 Nov 2025, 20:03 If the car is still on the ground, sometimes you have to make contact again and then switch off.
Raise suspension to highest
Jack rear up (both sides), support with axle stands
Set the suspension to lowest
Depressurise with Lexia
Switch ignition off
Disconnect battery
So now rear end is in the air. What does it mean by make contact again?
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
Oliver53
Switch ignition off
Disconnect battery
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
Oliver53
Solved using the bleed screw
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
PaulC5
- x 693
That is what I did when I replaced a rear boot and also I did not have a Lexia. I had a leaking boot so replaced it but it did not stop the leak and needed a new strut.
Kees
- x 148
This is the wrong way to depresses the system, it should be in the low position and then depressed total by the diagbox.
By your way there is still a column of lds fluid in the strut and because you disconnect the battery the valves in the BHI are closed and this is why you can't move the piston inside the strut.
Oliver53
I followed all the instructions on the Lexia (including the last step of disconnecting battery). But you are probably correct, valves should be closed by default and that can explain the behaviour.Kees wrote: 12 Nov 2025, 08:44 This is the wrong way to depresses the system, it should be in the low position and then depressed total by the diagbox.
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
Oliver53
in my case it turned out that it leaked through where the rubber meets the strut surface becuase it's corroded. I applied some RTV will see if it works.
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
