Hi,
I believe have an injector 1 problem on my misfiring 2011 Citroen C4 Grand Picasso. Please can someone supply me with full details on my engine type so I may get the correct part to replace it.
VIN No : VF7**************[VIN obfuscated, can be read by forum staff] Reg: VO11 CHD
Kindest Regards
Engine info required
- x 1941
Re: Engine info required
Your EDC (engine designation code) from your VIN is 9HR. This appears to be either a DV6CTED or DV6C 1.6l itre e-HDi 115 and fitted with a Siemens common rail injection system.
https://mymotorlist.com/engines/peugeot/dv6cted/
PaulC5
- x 698
Be aware that Citroen number cylinders from the gear box end and not the timing belt end as would be normal.
pic_a55o+c4gp
Hi Paul-R & PaulC5,
Thanks ever so much for the prompt responses and information. Can I take it that the DV6CTED or DV6C 1.6 litre e-HDi 115 would require the same injector part number?
For info I managed to borrow an Autel Autolink AL319 scanner yesterday so did a few tests and error clears and kept getting just one error code re-occurring "P0262 Cylinder 1 injector circuit High"
After digging around on the Forum and Google plus YouTube it seems there could be a few issues causing my problem. Maybe better to let a garage sort it rather than risk getting something wrong and screwing things up.
I will have another dig around for a while before deciding and or putting my amature car mechanic skill set to the test
Many Thanks
Many Thanks
- x 1941
Whether the injectors are the same, I don't know. Unfortunately we don't have access to the PSA parts database at the moment so can't be sure.
pic_a55o+c4gp
Ok thanks Paul-R
pic_a55o+c4gp
Hi Paul-R & PaulC5,
Sorry for late update. Issue with the engine, garage repair info, was a failed Cylinder 1 injector. had repair done by garage. For info costs below:-
Part : FEAA2C59513556 Diesel Injector £245.64
Labour : £180.00
VAT @ 20% : £85.13
Total : £510.77
Just a Heads up for anyone who has similar issue.
Thanks for your help guys.
Labour : £180.00
VAT @ 20% : £85.13
Total : £510.77
