Hello everyone,
I will need to replace the clutch kit, flywheel, and hydraulic bearing on my 2008 C4 Picasso 2.0 HDi together with my trusted mechanic.
I would like to ask if anyone knows in detail the steps to follow using DIAGBOX before and after the kit replacement. Is it a guided procedure in the software, or are these separate interventions?
From what I have read, the following steps are involved in this sequence:
Depressurizing the robot circuit
Replacing the mechanical components
Pressurizing the robot circuit
Bleeding the circuit
Learning the minimum and maximum clutch points ???
Learning the clutch disengagement/engagement point
I would be grateful if anyone who has maybe performed this procedure could help me understand what needs to be done.
DIAGBOX Procedure for Replacing Clutch Kit and Flywheel
MaxHdi
Huskyxantia
- x 925
Re: DIAGBOX Procedure for Replacing Clutch Kit and Flywheel
would this help ?
Husky.
- x 8146
I believe you do have the sequence correct there and hopefully one of our experienced members will be along to give their opinion soon.
- x 1056
Sounds about right but i would add you must have good battery support when carrying out the procedures, if the garage doesn't have access to a good battery support unit then i would connect another running vehicle with jump leads. Without battery support i find these procedures more often than not fail.
MaxHdi
Thanks, that surely helps. Anyway she's a more recent car and different diagnostic tool but gives an idea. As long it's a guided procedure it should't be too hard
MaxHdi
Do you know if Diagbox 7.57 has offline citroen service box?
