Spray EGR Cleaner
Thomasbrown
Spray EGR Cleaner
Unread post by Thomasbrown »
Hi all,
Bit of a basic question - sorry for my ignorance.
Where exactly do i spray EGR cleaner?
Is the blue circle my air filter housing? So i spray down the pipe circled red?
Citroen dispatch 1.6 Bluehdi XS 2018
Thank you
x 8142
Re: Spray EGR Cleaner
This video is on a 1.6 HDi C4 but basically the same as your engine. It will show you how to go about it, :)
Thomasbrown
mickthemaverick wrote: 24 Oct 2025, 12:01 This video is on a 1.6 HDi C4 but basically the same as your engine. It will show you how to go about it, :)
Thank you very much.
I was almost on the the right track. So is that the turbo?
x 8142
The bit he sprays into is the turbo yes :)
Ednic
x 5
Unread post by Ednic »
Does this stuff work?
Steve Walsh
x 518
Unread post by Steve Walsh »
Ednic wrote: 24 Oct 2025, 18:47 Does this stuff work?
I would be surprised if it worked, I have had various EGR valve's off different engines and sometimes struggle to get all the crap out by hand. I cant see how a spray wizin through would do much... Just my opinion
Ednic
x 5
My thoughts too, especially after having gone through the combustion process.
x 8142
You may find this article helpful: https://www.wynns.uk.com/professional/e ... e-cleaned/ :)
