I removed the plastic cover under the steering wheel (where the OBD socket is) to install a GPS tracking device in my car, and I found a loose connector there. Does anyone have an idea what it might be for?
C5 aircross LeftHD
Unknown socket
- x 8124
Re: Unknown socket
if you can post the number printed on the pink wire it may be possible to identify it!
owl
- x 15
Re: Unknown socket
I just checked the pink wire. There’s no number on it, only some black marks or stains.mickthemaverick wrote: 17 Oct 2025, 22:36 if you can post the number printed on the pink wire it may be possible to identify it!![]()
My guess is that it’s either for the Webasto on/off switch or the front windscreen heating element switch. I don’t have either of those features in my car.
OnlinePaul-R
- x 1938
Re: Unknown socket
You might have to unwrap the loom tape to go far enough back to see the numbers,
- x 3296
Re: Unknown socket
It is possible that (as you have suggested) it is for something that is not fitted to your vehicle. Rather than have a wiring loom for each possible variant most manufacturers have a few looms, and will use one to cover a few spec levels, another for the next levels, and so on.
