Citroen C4 GP 2009 Central Locking Issue
AdamC
Unread post by AdamC »
Afternoon all, the central locking has been a t..t since I bought the car and won't work on key fob for both front door but it opens all the other if I unlock it with the key from drivers door the passenger door stays locked and the rest open, if I unlock with key from passenger side the drivers door stays locked but rest open... I can't seem to find the issue, I can hear both motors engaging I've taking wiring out doors and can't see any splits and I've checked all fuses.... Anyone think of anything else other then it going to be crushed as its driving me nuts 🤪 ....
Thanks in advance 😎
x 8126
Re: Citroen C4 GP 2009 Central Locking Issue
Have you performed a BSI reset? :)
AdamC
Yep, I'm running out of options other then crushing the dam car 😂
x 8126
Which doors lock/unlock when you use the lock all button inside the car? :)
AdamC
All the doors lock with button but all doors unlock all the car when you open them 🤷???
x 8126
That sounds like there is a wire or two reversed somewhere, what was the last work done before the faults appeared? :)
PaulC5
x 696
Unread post by PaulC5 »
Water ingress in the front of this car is common so it might be there is some water damage causing a problem.
AdamC
mickthemaverick wrote: 18 Oct 2025, 17:33 That sounds like there is a wire or two reversed somewhere, what was the last work done before the faults appeared? :)
The fault has been there since I bought the car so unsure sadly.
AdamC
PaulC5 wrote: 18 Oct 2025, 22:11 Water ingress in the front of this car is common so it might be there is some water damage causing a problem.
I shall check around the front tomorrow and check for any corrision, thank you.
AdamC
Still having issues with this, Anyone have a wiring diagram for the central locking at all?
x 8126
If you can tell me your RPO number I can try and find the diagram :) This link and the 2 following posts show you where to find that if you don't already know: viewtopic.php?p=852428#p852428
AdamC
I just took a picture, have another issue which I'll open a new thread for 😂
Thank you.
x 8126
I had to select from a couple of options so this diagram includes remote dead locking and electric operated child locks. If that is wrong let me know:
c4 pic central locking.pdf
Copied from Sedre Backup
(3.47 MiB) Downloaded 72 times
You can find the diagram decoder at:
viewtopic.php?p=782862#p782862
AdamC
I shall study threw it, see what's going on, Appreciate that.
