Every blinking time...... replacing the top mount on my daughters 208 (2014 1l manual) and I've tied the driveshaft back but still I look away for 2 seconds and half the contents of the gearbox is now on the driveway.
I know I'll need to completely drain and refill but could anyone please advise grade and quantity of oil needed?
Many thanks
Peugeot 208 Gearbox oil?
- x 8085
Re: Peugeot 208 Gearbox oil?
Can you confirm the engine and gearbox combination in the car?
John1966
- x 4
1l 5sp man
- x 8085
I think you should find your answers here: https://willandservicecentre.co.uk/peug ... il-change/
John1966
- x 4
Lots of good info in that link but nothing specific to the 1.0 litre which I think is a fairly rare beast? According to the manual it's sealed for life!!!! SO will probably present a challenge to fill, so any suggestions in that department wouldn't go amiss either, thanks
- x 8085
Try this one for actual figures etc. https://oils-finder.com/index.php?model ... ugeot20812
John1966
- x 4
Found the spec PSA B71 2316, which is a 75w grade, and it would appear to take 2 litres, but now struggling to actually find the oil to purchase.
- x 8085
The description in this ad includes that specification: https://www.ebay.co.uk/p/13047368827
John1966
- x 4
But will they deliver to the Scottish Islands, will give it a go.... many thanks
Arkis
- x 27
In my "clever book" there is written "TotalEnergies Traxium Gear 8 75W-80" for my engine. It's 208, 2019, 1.2 61kW with 5 speed manual transmission. I think the transmission were the same? Just different ratio.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
John1966
- x 4
Fully drained and put approx 1.9 litre through the breather, so far so good, a few bits to finish off and I'll take it out for a bit of a thrashing tomorrow!!
