Sharp Areas of Steering Wheel
Snak3zZ
Unread post by Snak3zZ »
2013 Citroen C3 Picasso
Not my car admittedly, it's my mother in law's. The plastic part at the bottom of the steering wheel has cut my hands up. Upon trying to feel around the wheel I have then sliced my finger. It's sharper than glass.
We could of course tape it, but I worry this would wear and just be a reoccurring problem. Do we need to do something as drastic as buy a new steering wheel or can we replace the plastic bottom of the wheel?
I'll send photos later when I am at the in law's
Many thanks in advance.
P.S. First post on here, I am long time user of Aircross Forums. Look forward to helping out where I can.
Edit #1 - Have added photos, thanks for the suggestions so far :)
x 1940
Re: Sharp Areas of Steering Wheel
Welcome to the forum Snak. Yes photos would be very useful to see what's what.
x 2941
This or something similar may help, there are many out there.
https://www.ebay.co.uk/itm/167516831457 ... ae4e85367c
x 5673
Use a Dremel or similar to grind down the sharp bits.
shtu
x 76
Unread post by shtu »
Also, a used steering wheel is pretty cheap, £25-50 should get a replacement.
Snak3zZ
Thanks for the help all, I ordered a cheap £6 tool similar to a dremel and managed to sand it down. Much appreciated.
the-termin8r
x 143
Unread post by the-termin8r »
That looks like the same sort of issue the X7's parking brake button has. The chrome finish is starting to peel. Chances are it might start to peel up again in the future so worth keeping an eye on it. Stripping the whole trim piece of the coating should solve the finger slicing issue, but it'll look a bit naff.
- Rob
My account accidentally got deleted late Dec '23, so if you're reading my posts from then or earlier and they look weird / are missing media, that's why. There's no fix, sorry.
If you're reading any of my posts with missing design files, find them on my Google drive
