Citroen Xanita V6 Help needed Please
co04pow
x 3
Re: Citroen Xanita V6 Help needed Please
Unread post by co04pow »
Hi,
Was at the car today.
I started by checking continuity of as many cables as I could. Annoyingly the one I thought was broken (checked cable 120 from pin 1 to Fuse 9 on under bonnet fuse box (this does not have continuity so must be broken!)) was not broken I must have been on the wrong pin on the multi plug under the drivers side wing.
I have attached an image of the wiring diagram and coloured all the cables i have checked continuity with green pen.
I have marked where I was getting 12V with battery connected in red and one point between inside car fusebox and pin 14 on relay 1307 when ignition turned to position 2 in purple.
Also I wanted to rule out 1203 (which is the red inertia fuel cut-off switch) I was getting 12V at it so fitted a cable between pins to try and get 12V at pin 10 on relay 1304.
So Can you tell me if I an correct in saying the following:
I need 12V from ECU pin 3 through the inertia fuel cut-off switch to pin 10 on relay 1304, This will then give 12V at pin 1 and 9, supplying under bonnet Fuse 9 for the fuel pump. As well as pin 2 on relay 1307 but also 12V from pin 51 on the ECU to pin 10 on relay 1307 thus supplying pin 9 and giving 12V at under bonnet Fuse 11.
How do I know the ECU is getting power and sending it back out?
Why am I not getting 12V at pin 10 on relay 1304 even with the inertia fuel cut-off switch looped out?
Help very much appreciated.
Owen
2000 W reg Xantia V6 Exclusive (Green)
2000 X reg Xantia 2.0 HDi SX (Dark Grey)
1999 V reg Xantia 2.0 HDi Exclusive (Dark Grey)
1998 R reg Xantia Estate 2.1TD SX (Silver)
1996 P reg Xantia 1.9TD SX (White)
1996 P reg Xantia 1.9TD LX (Red)
1994 L reg Xantia 1.9TD LX (Silver)
x 1481
Unread post by xantia_v6 »
How are you testing continuity of the wires? Reading with a multimeter is not always accurate with a corroded wire, as it may show a low resistance, or correct voltage with no load but still not pass any current with a load applied. You need to check for voltage drop across the cable when it is carrying a load.
I think you need to take a step back and determine which voltages are present or absent at the relevant pins on the ECU and relays, I have become a bit confused.
co04pow
x 3
Ok,
Yes just using a multimeter for continuity.
So next time I am back I can pass 12V down each cable and see what comes out the other end and let you know values for relevant pins?
Owen
x 1481
For the power wires, you should apply a load, such as a 20W light bulb. It also give a visible test result.
thorter
x 44
Unread post by thorter »
A good way to look for loose and dry joints in the power distribution chain is using a filament bulb, say an 18 or 21 watt. Connect one side to ground, the other to a probe and to a meter on volts, and touch this along the supply path to be checked. Obviously look for low volts as you go. Don`t probe sensors, processors and so on, but the method is fairly safe.
thorter
x 44
Beat me to it!
co04pow
x 3
Thank you for the info, I'll let you know the outcome
