Hello everyone, I have RT3 CAN version (6.63) with a broken HDD and CD drive is not working. Could someone share a working HDD image dump so I can clone it to a new drive?
Thank you!
RT3 CAN 6.63 - need HDD dump
shtu
- x 78
Re: RT3 CAN 6.63 - need HDD dump
Would any of the images on this thread be any use?
https://www.peugeotforums.com/threads/r ... ade.27977/
- x 1941
If you can't get those links to work I have some more.
MarkoJ
In my Citroën C5 X7, 2009, I have a Citroën RT3 CAN (firmware 6.63) unit with a faulty CD drive. Because the CD reader is not working, I cannot perform a firmware update from CD.
What I really need is a full HDD dump (disk image) from a working RT3 CAN 6.63 unit.
By "HDD dump" I mean a sector-by-sector copy of the original 2.5" PATA HDD (usually 4 GB in size) that contains all 4 partitions and the RT3 operating system.
I would then write this image directly to my HDD using tools such as HDD Raw Copy Tool.
- x 1941
I know what you mean but I'll be honest, I think you'll be lucky.
- x 3296
The most likely cause for the CD drive not working is dust on the lens. Some CD cleaner disks do a good job of cleaning off the dust, but sometimes you have to open up the drive and clean both the lens and the friction washer (on the drive spindle).
shtu
- x 78
Indeed. I don't know much about the RT3, so no idea if the ISOs I could find would rebuild the whole disc structure from zero.MarkoJ wrote: 31 Aug 2025, 13:21 What I really need is a full HDD dump (disk image) from a working RT3 CAN 6.63 unit.
You may yet ind your best bet is to get the CD player working, as above.
Could also get hold of a complete used head unit, copy it, and resell it.
Also may be worth checking the CD's internal interface, as it's also possible to mimic a CD drive's behaviour using hardware, and use an SD card instead, eg, https://www.zuluide.com/
I think you're on a long shot here, the odds of finding another person with the exact radio you have, plus a willingness and the skill to open it up and clone the disc for you, is pretty slim. If there's anywhere possibly able to help, MHH Auto, eg, https://mhhauto.com/Thread-Peugeot-RT3-T6-N3-Upgrade-CD
Note - I know these are not the exact answer you are looking for, just alternates that might be possible.
MarkoJ
I got a suggestion to try to restore the software to the previous version. I found in the Backup folder that it is version RT4 CAN 8.10, and it should also work with RT4 CAN 8.11. Can you help me get to this file?
- x 1941
That's RT4 not RT3. Where did you hear that suggestion?
MarkoJ
I thought the device had RT3 software because it says so on its cover. I accessed the HDD and made sure there were 2 Backup folders as it was first upgraded to RT4 and then to RT4 CAN 8.10.
This is the reason why I need RT4 CAN 8.10 as the last version before the device crashed.
- x 1941
Even assuming I can find a source for this how will you load it without a working CD drive?
- x 1941
I have found links for 8.20 and 8.31 but not 8.10. I haven't tested the links as they are 425MB each!
MarkoJ
I have v8.31 but it won't boot. I can't find a v8.10/11 iso image so I'd like to try the v8.20 iso. Thanks...
MarkoJ
I think my CD drive problem will be solved. I took it to a repairman who said the CD drive is just "stuck" and that he will fix it mechanically, I hope.
- x 1941
Check your PM in a few minutes. You really are on your own with this!
