My water tank is being emptied intermittently by this fault. I don't have to touch anything, it empties on its own.
Is it a case of replacing the indicator and washer stalk units?
2013 C5 X7 haunted rear wash wipe
- x 8079
Re: 2013 C5 X7 haunted rear wash wipe
Can you expand a bit more on the 'it empties on its own' Do you mean as soon as you fill it it pumps it out the nozzle, or it leaks out somewhere in the system?
Camper Longflap
It works as if you're operating it from the stalk. Intermittently with no input. Frustrating as it sprays all my screen wash over the back window until it's spent.
Camper Longflap
I think it's one of these I need.
- x 8079
That is a possibility but before you buy one I'd suggest you unplug the old one to ensure it doesn't happen then.
PaulC5
- x 670
You could also check the wiring to the washer pump in case it is damaged and shorting as if the switch was being used. BSI resets sometimes fix odd electrical problems as well so might be worth a go.
Camper Longflap
Testing the wiring is beyond my paygrade unfortunately.... Incidentally is steering wheel removal required for replacement of the indicator/washer stalk assembly?
- x 8079
Even a visual inspection of the wires going from the pump maybe worth the effort as you are looking for insulation integrity. If there are any scuffs where the wiring goes through the hatch into the car main body they could allow shorting out on the frame. I agree testing can be challenging because of the way cars are wired these days but you should be able to visually inspect the wires for damage. If you find any then wrap insulation tape round the damage thereby isolating it from contact with anything else
davoxx
- x 15
Prob a broken cable at the hinge, I have a ghost issue where the wiper will start when the door is mid raise and then stop once it opens more.
why?
PaulC5
- x 670
I suspect the wiring to the pump will not go through a door but straight from the steering wheel stalk to a fuse box and then to the pump.
davoxx
- x 15
Oh yeah, forgot he said the jets were going. That makes more sense.
why?
