Peugeot 3008 hybrid 2015
Pepe autotechnics
x 9
Unread post by Pepe autotechnics »
Hi I have a Peugeot 3008 hybrid 2015 and on diagbox I have fault codes attached as pdf photo codes are P1AC2- reduction gear position fault and P1B70- electric drive machine position sensor fault and P1AC4- drive train fault could these faults be because of the sensor and where is the sensor is it the sensor mounted on the electric motor differential?? Fault appears in hybrid mode when decelerating on over run as electric motor changes hybrid battery jumps out of hybrid mode!!
Sorry in my earlier post I sent the wrong attachment jpeg here is the correct attachment jpeg, is the answer the same!!
x 8146
Re: Peugeot 3008 hybrid 2015
Please don't open duplicate threads about the same problem, you have had a reply from Husky on your original thread so I will lock this one after this post. You can go back to the initial thread via this link: viewtopic.php?p=847619#p847619
