DPF additive low
Cstanleymidgley
New User
DPF additive low
Unread post by Cstanleymidgley »
Just had this warning light pop up on my 2012 DS5 2.00 Diesel. Is this a big job?
x 8166
Re: DPF additive low
Big job or not really depends on your facilities and experience. I would class it as a fairly simple job for a dealer or specialist independent with ramp facilities but can be a pain if doing it at home. :)
PaulC5
x 717
Unread post by PaulC5 »
Once topped up it will need a diagnostic to tell the car, if not done you will continue to get the warning message since the level is not measured, just calculated.
