DPF additive low
Cstanleymidgley
- New User
DPF additive low
Just had this warning light pop up on my 2012 DS5 2.00 Diesel. Is this a big job?
- x 8166
Re: DPF additive low
Big job or not really depends on your facilities and experience. I would class it as a fairly simple job for a dealer or specialist independent with ramp facilities but can be a pain if doing it at home.
OnlinePaulC5
- x 717
Once topped up it will need a diagnostic to tell the car, if not done you will continue to get the warning message since the level is not measured, just calculated.
