Saxo 1.6 Automatic Gearbox Type?
x 8370
I've had an enquiry via my CCC column to ask about swapping the ATF and any allied routine service work on the automatic gearbox fitted to the very rare series 1 1.6i Saxo Automatic...
All I can determine from my enquiries/searches is that it's a 3-speed and not an AL4... I'd like to know exactly what it is.
Also, can anyone shed any light on the correct grade of ATF to use (Dexron II or III?), any filters to clean/replace and if a diagnostic session is needed to reset any worn oil counters and if any reinitialisation is required.
Thanks all :)
x 2000
Re: Saxo 1.6 Automatic Gearbox Type?
Unread post by Stickyfinger »
1.6 gearboxes....take your pick....if it helps
x 8370
Thanks Alasdair, that's appreciated :) I thought it might be an MB but in my current fuzzy state I just couldn't think what its designation was... That's actually a Renault 'box and also used in the 106...
Seems it needs Dexron III and is electronic.
x 1056
Unread post by wheeler »
As far as im aware the only auto box he Saxo ever used was the MB3
Takes Total ATX which is the same as Dexron 3
Nothing fancy needed with Lexia.
x 8370
Thanks wheeler, that's massively appreciated :D
citroenesque
x 4
Unread post by citroenesque »
Hi there,
Very helpful, thanks guys!
However, I must point out the Total Fluide ATX (or as it's branded now "TotalEnergies Fluidmatic ATX Automatic Transmission Fluid") is actually specified as Dextron II D.
This is backed up by further research re: the MB3 'box, with PSA listing "PSA Peugeot Citroën: S71 2102"
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
