Peugeot 107 2013 - Permanent 12V inside car
RKN704
Unread post by RKN704 »
Looking for easiest place to connect a solar panel inside the car for maintaining the battery when locked and parked for extended periods.
Is there a convenient place to connect to a permanent 12V. Cigarette lighter socket no good as it is switched by the ignition switch.
Thanks in advance
x 8126
Re: Peugeot 107 2013 - Permanent 12V inside car
Which 107 trim spec are you referring to? :)
RKN704
it is a 107 Allure, 5 door model
x 1055
Unread post by wheeler »
A lot of these solar trickle chargers come with an OBD connector on them so it can be plugged straight into the diagnostic socket.
If it doesent have one then should be easy enough to make one up. Pin 16 is permanent +12v & pins 4 & 5 are earth
Blank connectors are readily available on ebay, Ali express etc.
x 8126
Following Wheeler's advice this is an example of the plugs available: https://www.ebay.co.uk/itm/254716180279 ... R_Cx6PWNZg
RKN704
Thanks for the info. I think that will be the neatest way.
Should I be getting email notifications when someone replies to my posts? Not seeing any at the moment.
x 1055
Think you may need to opt in to receiving notifications, im guessing it will be in your user account settings.
At the top of the page there is also a subscribe to topic option you can tick
x 8126
You need to go into your User Control Panel from the drop down at the top right of your screen. Then select the Board Preferences tab and go into Edit Notifications and set them up as you want. :-D
Click on the image to enlarge:
An example of the screen
