Peugeot 3008 allure 2021 diagnostic
Aidulis73
Unread post by Aidulis73 »
Hello my Peugeot does not start i ran diagnostic and i get these faults could someone explain be what could be the problems and how to fix it please 🙏
x 8124
Re: Peugeot 3008 allure 2021 diagnostic
I would suggest you clear the faults recorded, carry out a BSi reset according to the link below and then rescan if the car still doesn't start:
viewtopic.php?p=601679#p601679
PaulC5
x 690
Unread post by PaulC5 »
When it does not start, is it turning over on the starter motor ? Before where there any problems when it was last used ?
Aidulis73
Right I bought this car of copart and the car did not start.we changed engine ECU as there was a problem and changed battery as it was dead but we have not changed auxiliary battery could that help if we do ? As one of the Faults show auxiliary battery switch .
x 1939
If the replacement engine ECU wasn't a new one, or a virginised second hand one, then it will not be matched to the BSI and starting will be inhibited anyway.
Aidulis73
We kept the old ECU the problem was actually with connector but we changed that
Aidulis73
mickthemaverick wrote: 21 Jul 2025, 10:59 I would suggest you clear the faults recorded, carry out a BSi reset according to the link below and then rescan if the car still doesn't start:
done the BSI reset but the car still does not start
