Hi
Could anyone please advise how to resolve the Sat Nav thinking it is around 400 miles away from where I am?
I have had two garages look at it and they have not been able to resolve, they suggested a main dealership.
Does it need updating? Is an update something I can do myself?
Thank you very much
Sat Nav map in wrong area - C4 Picasso 2018
gardenpond11
- New User
- x 1450
Re: Sat Nav map in wrong area - C4 Picasso 2018
It could be a result of the 2019 GPS roll-over issue. Go into the navigation settings and find a check box for setting the date automatically, and un-check it.
- x 1938
It could also be the actual head unit which is not a cheap repair. A further possibility is that the GPS aerial has gone faulty. A fairly cheap test would be to buy a standalone GPS aerial to plug into the back of the head unit.
- x 8085
The satnav relies on GPS for its location information and so the first place to look is the GPS antenna. This video, although working on a Seat , shows the principles which you need to check first.
