Eurovan 2 Lancia Phedra RT 6 RENG2
Bacchus90
Hello, I am new here. I am familiar with Peugeot 807 and Citroen C8. Now I bought a Lancia Phedra with full Specs. It had a RT5 HDD navigation. I like to keep it factory no China Android aftermarket Radio. Bit would like to have a updated Navigation system. So I bought a RT6 RENG2 (lastest updates)and a new Display spend almost 900€. The seller coded my VIN to the Radio unit. I installed everything and it turns on (with a Citroen Logo
) I don't mind. Controls are working and it all the other information are correct displayed. But hand here is my big problem the trip computer stuck on the old range and fuel consumption from the old nav system. I filled up Diesel and nothing changes. Any ideas ? Thank you!
Reason: Image fixed
Reason: Image fixed
- x 8126
Re: Eurovan 2 Lancia Phedra RT 6 RENG2
Have a read through the link below and see if it helps:
viewtopic.php?t=75448
Bacchus90
I checked my software version it's 2.86B1. so no calibration needed, correct?
- x 8126
I have no knowledge of the system but at the end of the post I linked, it advises how to check if you need calibration or not using Diagbox. I think you need to check that way as you have upgraded from RT5
Bacchus90
Okay it worked out fine ! Just had to , connect and disconnect again
Phedra007
Hello.
Can i ask you where did you buy radio, screen and all other equipment which its needes for rt4 upgrade and what exactly i need for upgrade to rt6.
Thank you for answer
