Bonnet cable will not open the bonnet
TehAgent
- x 7
Well, as per the title.
I have a Peugeot 208 2014
Is there anyway to manually trigger the bonnet latch as the cable will not do it. i have managed to get the front grill off and pull the cable through from the cabin area, but it will not "pop" the bonnet in order to get it open.
Seems Peugeot didnt think of anyway to access the latch as there seems to be nothing i can get on to to activate the opening mechanism, unless someone else has some pointers.
Unfortunately, everything ive searched for online, hasn’t managed to provide a solution to the problem. Ive tried the pushing on the hood, while someone pulls the catch, you cant pull the cable, it just doesnt move, its like its solid.
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 8100
Re: Bonnet cable will not open the bonnet
When you say you've tried pushing on the bonnet with someone pulling the cable, did you apply continuous pressure? It is more likely to release if you sit on the bonnet and bounce it while the cable is gripped in molegrips and pulled with a series of jerks!! (That doesn't mean the local rugby team
) Good luck
- x 8378
Welcome back to Pug ownership Ian and great to see you back on here again
TehAgent
- x 7
tried no end of different options with that sitting on the bonnet and pulling the cable.mickthemaverick wrote: 21 Jul 2025, 15:33 When you say you've tried pushing on the bonnet with someone pulling the cable, did you apply continuous pressure? It is more likely to release if you sit on the bonnet and bounce it while the cable is gripped in molegrips and pulled with a series of jerks!! (That doesn't mean the local rugby team) Good luck
Need to gain access to the actual latch now but it seems to be hidden behind a bunch of plastic i cant get past to manually operate it to release the bonnet.
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
TehAgent
- x 7
Cheers bud, thought id signed up with the email associated with this account, apparently i didn’t lolCitroJim wrote: 21 Jul 2025, 15:42 Welcome back to Pug ownership Ian and great to see you back on here again![]()
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 8100
The key to the sitting on the bonnet is to actually bounce yourself on it to give it a series of shocks rather than just continuous pressure. The next option may be to work out which bits of plastic may be replaceable and attack with the angle grinder to gain access to the latch. Obviously it may mean replacing panels so try and minimise the number of them it is necessary to cut through.TehAgent wrote: 21 Jul 2025, 16:28tried no end of different options with that sitting on the bonnet and pulling the cable.mickthemaverick wrote: 21 Jul 2025, 15:33 When you say you've tried pushing on the bonnet with someone pulling the cable, did you apply continuous pressure? It is more likely to release if you sit on the bonnet and bounce it while the cable is gripped in molegrips and pulled with a series of jerks!! (That doesn't mean the local rugby team) Good luck
PaulC5
- x 680
Probably a stupid question, but you are pulling the inner cable and not the outer to release the latch ?
TehAgent
- x 7
only one cable, even took the leaver off the interior of the car, and pulled the wire directly.
From what i can see on ebay listings of the actual latch, there might be away to get to the mechanism. but its very very tight in there and you cant see what you're doing.
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
TehAgent
- x 7
This is the back access, so if youre at the front of the vehicle facing the bonnet, this part would be the rear side of what you would be looking at.
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
TehAgent
- x 7
Well, had the car on drive on ramps earlier, removed the front under-tray and tried to get to it from underneath within the engine bay, but no such luck.
I can not understand for the life of my why there is seemingly no way to access this from anywhere else.
Its getting to the point im thinking im going to have to actually cut into the bonnet, and replace that, just to gain access to the engine bay.
There are other Peugeot out there with seemingly similar issues, from what i can tell, just closing the bonnet too hard can pop the cable off of the release arm.
anyone breaking a black 208 with a good bonnet?
On a plus note, changed the two lower control arms for new ones as the rear bushes had perished.
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 8100
Can you get the grill off and then cut through the surrounding plastic rather than cut the bonnet?
TehAgent
- x 7
i really need a good image of the latch area with the bonnet open to understand where id need to cut and if that would make a difference.mickthemaverick wrote: 24 Jul 2025, 16:59 Can you get the grill off and then cut through the surrounding plastic rather than cut the bonnet?![]()
My understanding is that part is attached to the front bumper
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 8100
How about this:
and this video may also show you some more of what is involved:
TehAgent
- x 7
So the bit i need to cut, is hidden behind the bonnet when its closed....
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 8100
I think I would take off the chrome surround, probably prises off with a plastic trim tool, remove the number plate and then cut into the grill, if you can't get it off because the top fixings are under the lip of the bonnet, roughly as I've drawn on the picture. Then you should be able to get a hook up onto the release lever and pull it open.
If you cut it carefully you may even be able to glue it back together afterwards as the number plate will hide most of the join.
