Hi all
my car:
3008 year 2022 - Diesel
I have an error related to the trailer relay
U1F45 Fault
"absence of communication with the trailer relay unit"
Please advise
1 - where is this relay is located in my car?
2 - What can trigger this error?
and
how can I resolve this issue?
The trailer socket is dry
Thanks!
Eran
3008 - Trailer relay unit locatin
Er3008
Reason: Image fixed
Reason: Image fixed
- x 8149
Re: 3008 - Trailer relay unit locatin
This link takes you to a site which has the trailer box fusing details, and checking the fuse may be a good place to start. I haven't as yet discovered where the actual box is but I'm still looking!!
https://fuse-box.info/peugeot/peugeot-3 ... 2016-fuses
This video shows you how to confirm the trailer unit is configured.
PaulC5
- x 699
In the UK you get a 3 year warranty on cars, if this applies in your country then you should be able to get your dealer to fix this.
- x 1943
On my C5 X7 Tourer the towing (which I presume is the same as trailer) ECU is hidden behind the trim panel between the rear wheel arch and tailgate. I further presume that any relay would be part of that.
PaulC5
- x 699
If the relay is working and you switch the hazards lights on you might be able to hear it clicking and help locate it.
