Confessions of a Citroholic
x 1489
Re: Confessions of a Citroholic
Sigh :roll:
NSF - That's only been in there 10 months / 6k miles. It was a Lesjofors spring, so not unbranded. I think probably a new strut and top mount is in order, but a quick check on Autodoc indicated £330 fir a pre built unit so more research required. The other side the top mount is def broken as the middle was loose when I did that last year, so both sides needed.
x 8126
As you know Richard I have just completed renewing struts all round and I used KYB springs with a 5 year warranty. This is the ad for mine but I expect the same place will have them for yours :-D
https://www.ebay.co.uk/itm/176451995966
x 8401
That's not lasted long Richard... Do you have rather lumpy roads up your way? Can't imagine any worse than ours around here - mostly they look like the RAF have been using them for target practice :twisted:
x 1489
Yeah, roads are pretty rough!
Thanks Mick, KYB was on my mind - apparently the OE struts are often KYB. A complete set of bits from Pug is £437 so we won't be going there!
x 695
Unread post by Mandrake »
RichardW wrote: 06 Mar 2025, 19:00 Yeah, roads are pretty rough!
If only someone had invented a suspension system that lets you float above the road and then actually continue making it.... oh, never mind... :( #-o
x 8401
Mandrake wrote: 28 May 2025, 15:02
Yes, with every passing day we need it more and more Simon...
Good to see you on here again :) Don't ne a stranger ;)
x 1489
Had to fit a new CV boot clip on the C4 last week - was checking the tyres, they are not far off needing replacement. Also noted that both roll bar links have destroyed top boots - they are the Meyle HD ones fitted just less than 5 years ago - if I can find where I bought them from, they may be under warranty 😄 Now it's moaning about needing AdBlue as well, and it needs a service. And cambelt. And front suspension 🙄
Today the 3008 got in on the act, it's very angry🤬
It was fine on the way to work this morning, then an hour later Beep Beep Beep soon as I open the door, the red Handbrake warning is on. ABS and ESP come on when started - but they're not as important apparently, as only in yellow 😄 Got diagbox on it - no faults in the handbrake 🤣 but permanent fault on RR ABS sensor. No idea why it should give up just like that, comes with a wire attached so seems unlikely it's worn through like the C4 Picassos ones do. Getting it off looks fun, this has the discs with integrated hub / bearings, the sensor is bolted in behind. Apparently you can get to the bolt through a wheel bolt hole, but it's only 5mm Allen head, so what chance it's not just a rusty blob on a 12 year old car.... Probably have to take the disc / hub off and drill it out....😜
And I've still got to do the front suspension on it as well.
Reason: Images corrected
x 8126
So what are you going to do after lunch then Richard? :-D
x 1489
Fix my bike, and No 2 Son's bike, which are also broken, of course :rofl2:
x 1489
Remarkably after only about 10 mins work:
Winner! Just got to wait for the new one to arrive. Looked like a Torx, but they slipped, so tried the 5mm allen I had read elsewhere, and it came right out :mrgreen:
x 3565
Time to buy a lottery ticket ! :-D
x 1489
RichardW wrote: 10 Jul 2025, 20:54 Also noted that both roll bar links have destroyed top boots - they are the Meyle HD ones fitted just less than 5 years ago - if I can find where I bought them from, they may be under warranty 😄
Found the order on Ebay - only 4 years warranty and they were bought 4 years and 1 month ago. Obviously :rofl2:
x 1489
Fitted the new ABS sensor, it's not angry any more 😁 managed it through the disc, but it was a bit of a challenge to get it clean enough to sit square, and get the bolt back in - had to pack it with a couple of washers as the new bolt was slightly longer. Surprised that the fault cleared without needing the intervention of the computer, even before driving it.
x 8401
That's great Richard :D
x 1489
Was away for a few days this week. Was going to use the Picasso as taking bikes, but the rattle from the front has been getting worse, so gave it a quick look. About 1/2" of play in the NS track rod end :shock: it was OK a few weeks ago when I put the clip on the driveshaft - which it also turns out wasn't quite tight enough - but it's shagged now!
Got a new end and fitted it today, so at least it's not likely to fall off now! Put another clip on the driveshaft boot, but a tell tale clacking on full left lock suggests one of the joints is not that happy....
So we went away in the 3008. Not to be outdone, after a few miles I suspected I could hear the tell tale whine of a wheel bearing. By the time we got home (350 miles) it was no longer a suspicion - it's pretty vocal at 70 #-o so add a wheel bearing and bottom ball joint (they invariably have play when you get the hub off) to the list when doing the struts :-D
Going to change the oil in the Picasso tomorrow, but the garage can do the front end and timing belt - too much just at the moment.
