C5 Lexia help!
- x 1240
Re: C5 Lexia help!
Thank you all for your assistance, the new VIN get in OK but after loading all the sections it comes up "iD 205 m not found" any suggestions?
Thanks.
Thanks.
- x 1476
Re: C5 Lexia help!
Can you give a bit more context for that error? Is it a pop-up window? What was the last thing you clicked before the error?
- x 1240
Re: C5 Lexia help!
The last thing was the list of functions, it comes up in a little box in the middle of the screen, came up when I tried to select "Engine ECU"
- x 1946
Re: C5 Lexia help!
What version of Diagbox are you using? And remind me what year the car is?
- x 1476
Re: C5 Lexia help!
Try reading some other ECUs , to see if the problem is restricted to that one.
- x 1240
Re: C5 Lexia help!
The car is a C5 x7, don't know which lexia it is but it has a picture of a DS on the label plus the usual. I will try it on the other car and see if it works.
- x 1946
Re: C5 Lexia help!
When you're using Diagbox the version is displayed towards the top right of the page. If you've taken any screenshots when using Diagbox that might show the version.
- x 1240
Re: C5 Lexia help!
It says 'Diagbox' on the screen for me to connect to.
- x 1946
Re: C5 Lexia help!
If you have any test results printed out or saved as a PDF or JPG (or any image format) then the version is printed at the top.
- x 1240
Re: C5 Lexia help!
I don't I have seen a screen like that.
- x 1240
Re: C5 Lexia help!
Sorry should have been 'I doubt'.
- x 1240
Re: C5 Lexia help!
Car year 2009.
- x 1946
Re: C5 Lexia help!
Unfortunately my Diagbox is on a different laptop which I can't access at the moment so can't screenshot what the operating screen is like. Maybe someone else can oblige?
Having said that, for my 2013 X7 version 7.57 was sufficient.
How sure are you about the hardware side of your Diagbox? Is it full chip for instance?
- x 1240
Re: C5 Lexia help!
I don't really know but the fact that it has a DS picture I would have thought it would not have been too old.
- x 8157
Re: C5 Lexia help!
Peter are you using the one I gave you or another one?
