- x 8152
If you are in the mood to get beboggled Matt, watch this video all the way through, but I'm really posting it just to give an idea of why the fuse boxes these days are so expensive!!
- x 2366
Very interesting Mick, thank you. I'm not sure if the 308's BPGA has as much as is hidden in there, but will have a look at some point.
On that note, Jim - were you itching to have a look at the BPGA (or am I mixing up with the starter motor?)
- x 8435
MattBLancs wrote: 02 Jul 2025, 21:08 On that note, Jim - were you itching to have a look at the BPGA (or am I mixing up with the starter motor?)
Yes Matt, very keen to look at a BGPA
Huskyxantia
- x 927
Check out the corrosion creeping around this unit
Husky.
- x 2366
That BPGA looks pretty crusty (much like mine did) and mucky inside (which mine didn't really)
Today's investigation is having a look at the non functional GPS.
Aerial off, courtesy of a handy YouTube:
easier on his a lacking the Moon Roof - the roller blind mechanism surrounds the aerial base.
Also missing is that it's a 22mm nut and needs a socket to get at it.
Aerial looks horrible underneath: Part number
9666452880-03
Only brings up second hand items in eBay. Tiny little Torx screws but might take bottom off see if looks as though has seen damp internally
9666452880-03
- x 2366
The two rusty and three crusty heads are T7 Torx - smallest I've got a tool for.
Actually maybe smallest I had tool for... Oh. Not coming out then
Huskyxantia
- x 927
I just found this on AliExpress:
?2.59 | Car styling Shark Fin Antenna Auto Radio Signal Aerial Roof for Chevrolet Cobalt Celta West Uplander Cavalier Astra
https://a.aliexpress.com/_ExFfXJ4
Was considering one of them myself
Husky.
- x 2366
Not sure about that one - is it actually an aerial or just a snazzy cover for the existing aerial? (Very, very cheap if actually has any electronics!)Huskyxantia wrote: 06 Jul 2025, 18:57 I just found this on AliExpress:
Also, 17cm long seems huge!
I've read this:
viewtopic.php?p=750375#p750375
And so am going to buy this:
https://ebay.us/m/PH2yBy
GPS Fakra aerial. £4.49 free delivery. Realise it's not much cheaper than the AliExpress one above.
Huskyxantia
- x 927
I'd go with the one you posted , Ali can be a bit rubbish at times.
Husky.
Huskyxantia
- x 927
It was an aerial , the ali one , the listing video was a bit vauge poking the coxia in the hole ? Sticking it to the roof then tipping a bottle of water over it watching the clip twice it didn't really convince me
Husky.
- x 2366
DoneHuskyxantia wrote: 06 Jul 2025, 20:35 I'd go with the one you posted , Ali can be a bit rubbish at times.
Expected "15-18th July" but not going to grumble on postage speed given the overall cost!
- x 2366
Interesting to read what the FAKRA connector colours mean:
Taken from https://amphenolrf.wordpress.com/2015/0 ... explained/
- x 2366
Curry, white, blue and "gray" connections.
Oh, and (looking why left rear boot mounted lamp cluster is wobbly) I present the smallest wiper motor I've EVER seen! Ah, nowt but a baby!
- x 3565
Too dark for a pasanda, too light for a tikka masala..... wonder what sort of curry they had in mind ?
- x 8152
I'll go for a chicken korma:
