Citroen c5 x7 radio audio cutting out at random intervals
lasiakutevs
- x 7
Hi, I have an RT6 radio with a Philips amp, and sometimes the audio cuts out randomly for a few seconds. Sometimes it happens frequently, other times not. Has anyone had a similar issue, and how did you fix it?
lem0nv0iture
Re: Citroen c5 x7 radio audio cutting out at random intervals
Is it cutting out on any particular audio sources such FM/DAB radio, aux, etc? Mine used to cut out on DAB after I installed a dash/reverse cam. The cables gave off RF interference until I wrapped baking foil around the cables to insulate them.
lasiakutevs
- x 7
no, it cuts out on any source you are listening to for a few seconds
- x 8152
Since it happens on any sound source I would tend to suspect intermittent power supply issues. Maybe a poor connector or even a dirty fuse which is intermittently breaking the supply to the unit?
lasiakutevs
- x 7
maybe, the fuse for the amp is in the engine bay if im right
- x 8152
You should be able to find it for certain at: https://fuse-box.info/citroen/citroen-c ... 2017-fuses Good luck
wurlycorner
- x 271
If intermittent power issue, don't forget to check the ground side as well (and the pre-out / remote connections from the back of the stereo).
Might potentially also be dry solder joints in the amp.
Iain
CX DTR T2 Safari (silver)
Iain
lasiakutevs
- x 7
I removed the radio and checked all the connections, but didn’t find anything unusual. Then I took out the amplifier — again, nothing suspicious, just some dust, which I cleaned. I also removed and cleaned a dirty fuse. The problem hasn’t come back since, so I guess one of those things did the trick.
- x 8152
Good job, my money is on the fuse!!
