Xantia - steering completely solid
x 8437
Re: Xantia - steering completely solid
Stickyfinger wrote: 05 Jun 2025, 23:01 As I know only to well (as does Jim) it is very very hard to reattach the inner boot ends with the rack in the car.....please check this before fitting the rack.
Yes! Definitely this!!!
Jaf
x 42
Unread post by Jaf »
I am a little cross. Got new longer track rods, fitted them. Only to find that the hydraulic fittings are different too. The sizes and type of thread, plus no spring with washer. Help!! Please.
If I ever get this rack fitted I'll be shocked. But will check the boot fitting!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
x 1480
Unread post by xantia_v6 »
There was a point in S2 production where many of the hydraulic fittings changed, and then towards the end of the run, some changed back to the original type. I don't currently have access to my documents to check if that applied to the steering hydraulics.
x 8437
What a ball-ache Jaf :evil:
wurlycorner
x 271
Unread post by wurlycorner »
Argh I’m sorry this is turning into such a nightmare. When you finally do get the rack fitted, I hope it sorts your issues.
Iain
CX DTR T2 Safari (silver)
