How to identify what model engine is in your Citroen
akerolf
Re: How to identify what model engine is in your Citroen
Can you help me with build sheet to my car. VF7**************[VIN obfuscated, can be read by forum staff].
Tanx!
Tanx!
Beagle780
- New User
Hi can I kindly get my data sheet. I need to identify my exact model for some new parts
Vin no VF7**************[VIN obfuscated, can be read by forum staff]
zaskar2097
Hi! I'm thinking of buying a Citroen C5 X in the 1.2 Puretech 130hp EAT8 version. However the dealer can't seem to be very insightful of what equipment efectively comes with the car...
(for example I'm still not sure whether the car comes with wireless phone charger and heated steering wheel...)
Could anyone please provide me with the factory build sheet? VIN is VR7**************[VIN obfuscated, can be read by forum staff].
Thanks!!!
Thanks!!!
- x 1055
akerolf wrote: 30 May 2025, 21:58 Can you help me with build sheet to my car. VF7**************[VIN obfuscated, can be read by forum staff].
Tanx!
Vehicle characteristics
Vehicle family C4 (B7)
AS/RP N° 12719 88 1 0182
Warranty Start Date 10/11/2011
Engine serial number 10 JBEH 3015534
OPB 0005
BER e2*2007/46*0040*07
P4A 9691298999
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C4 (B7)
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL UPPER LOW PLUS
ENGINE DV6C TURBO DIESEL
TRANSMISSION STT 6-SPEED PILOTED MANUAL GEARBOX
PAINT TYPE METALLIC LACQUER
BODY COLOUR KTV - BLACK PEARL PAINT
INTERIOR TRIM TYPE W&W SAINT CYR G028 + DINAMICA G144 "XS"
UPHOLSTERY COLOUR "FC"
GEARBOX (CHARACTERISTICS) MCD MANUAL GEARBOX
ENGINE (TYPE) DV TYPE ENGINE
OTHER BADGE, " MISC. " EXCLUSIVE
STEERING VARIABLE POWER STEERING
SPEEDOMETER DRIVE WITHOUT SPEEDOMETER RATIO
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGE TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
CAPACITY 1600 CM3
CATALYTIC CONVERTER 2 COMPOUND CAT CONVERTER LOWER FILTER 10PPM 80GR
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANK FUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTION OPTIMISE+
COOLING MOTOR RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) ENGINE POWER 82 KW - 270 NM
VALVE PER CYLINDER 2
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECIRCULATION + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT SIEMENS ASSEMBLY
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND START WITH STOP AND START
Gearbox Transmission
FINAL DRIVE RATIO CP 19 X 71
WHEEL STYLE ALLOY WHEEL B71 16" EXCLU STYLE 2 ’BOSTON’
CLUTCH WITHOUT CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) TYRE 205/55 R16 91V NON REINFORCED
WHEELS FITTED 7" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR TYRE DEFLECTION INDICATOR
GEARBOX TYPE MC MANUAL GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 25
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITHOUT POWER STEERING OIL COOLING
SUSPENSION LOWERED SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCE WITH EMERGENCY BRAKING ASSISTANCE
BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
PEDAL BRACKET (TYPE) PEDAL STANDARD
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL ROOF AERIAL + GPS + INTEGRATED
REAR SPOILER AERODYNAMIC RR DEFLECTOR OPTIMISED SPOILER
DECORATION (PAINTED) GLOSS BLACK DECOR
SIDE MOULDINGS (TYPE) WITHOUT LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION) WITHOUT SIDE PROTECTOR, WITH CHROME SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
REVERSING LAMPS WITH TWO REVERSING LIGHTS
INDICATORS SIDE MARKER LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) BOAT + LORRY EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECT FOLD DRIV+PASS + REVERSE GEAR DRIV+PASS
SPLASH SHIELD STANDARD MUD GUARD WITH FOAM
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING SOUNDPROOFING UNDER BONNET + BULKHEAD + LOWER
WINDSCREEN WIPER INTERMITT AUTO FR WIPER BLADE + WATER LEVEL
REAR SCREEN WIPER WITH REAR WIPER
HEADLAMP WIPER HEADLAMP WASHWIPE
REAR SCREEN WIPER (OPERATION) AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
FRONT PANEL BLANK OPTIMISED LOWER BLANKING PIECE (MOTORISED) FR FACE
ROOF GLASS WITH ROOF WINDOW
REAR TAILGATE GLASS FIXED TAILGATE WINDOW
OUTSIDE TEMPERATURE SENSOR WITH EXTERNAL TEMPERATURE SENSOR
BUMPER BODY COLOUR FR+RR BUMPER + CHROMED STRIP
MUDFLAP WITHOUT REAR MUDGUARD
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP FOG LAMPS WITH CORNERING LIGHT
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) ELECTRIC DRIVER’S EXTERIOR MIRROR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
REAR SCREEN WASH REAR SCREEN WASH
BODY CONVERSION WITHOUT
BUMPER TRIM BUMPER WITHOUT TRIMMING
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
EXTERIOR STYLING PACK GLOSS BLACK DECORATION (DDY06) + CHROME WINDOW TRIM (DGV04) + TINTED + DARK-TINTED WINDOW (DVD09)
RADIO-INFORMATION-COMMUNICATION PACK WITH HANDS-FREE TELEPHONE KIT (DDO01) + eMyWay (DRCT6) + 1 JACK SOCKET + USB (DYM04)
HANDS FREE ACCESS AND STARTING WITHOUT HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS
BLIND SPOT DETECTION WITH BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
LUGGAGE COVER SHELF
REAR SEATBELT 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP) VERY COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX
CHILD LOCK MANUAL REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
TACHOMETER DIGITAL REV COUNTER
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION LEFT-HAND DRIVE
REMOTE CONTROL WITH REMOTE CONTROL
ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
BOOT AND LOAD SPACE LIGHTING BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT STANDARD FASCIA + INJECTION MOULDED BASE
INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
MISC. INT. LAMPS LC FR/RR LEDS WITH AMB LED WITH AMB LTG
LOAD SPACE TRIM BOOT CARPET MAT
UNDERSEAT STORAGE 2 UNDER SEAT STORAGE DRAWERS
INSTRUMENT PANEL (CHARACTERISTICS) INST PANEL CROWN PERSO+MATRIX
DOOR TRIM CYRION GREY DECOR
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING WITH ISO RR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFING BULKHEAD S’PROOF 5.5KG+TAILGATE+QU PAN+WHEELARCH
FRONT PASSENGER SEAT HEIGHT CONTROL PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT SEAT ARMREST FRONT SEAT CENTRAL ARMREST + ADJUSTABLE
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS DISCHARGE BULB
REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
CABIN CARPET R1+R2 PASSENGER COMPARTMENT CARPET MAT
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY DISPLAY DG4
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
FOOTREST FOOTREST WTH DRIVER + PASSENGER
CUSHION PADDING STANDARD FRONT SEAT CUSHION PADDING
OIL GAUGE STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
PASSENGER AIRBAG WITH AIRBAG ON PASSENGER SIDE
ELECTRIC WINDOW (OPERATION) DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
ON-BOARD COMPUTER COMPUTER
EQUIPMENT PACK WITHOUT DRIVING SCHOOL EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME EFFECT DOOR HANDLE + COLOURED TRIM
REAR LOAD FLOOR WITHOUT REAR LOAD FLOOR
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITH DIRECTIONAL LIGHTS
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
STORAGE (DRIVING POSITION) STORAGE COMPARTMENT + BLACK HANDLE
RADIO RECEIVER ’RT6’ AUDIO/TELEPHONE REMOTE DISPLAY
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
DRIVER’S SEAT HEIGHT CONTROL PARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS) STANDARD STORAGE COMPARTMENT + SEAT BACK POCKETS
CARPET COVER CARPET MAT 1
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE BOOT LATERAL STRAP + NET
CARPET NEEDLED CARPET DILOUR F550
TUNER RADIO DUAL RADIO TUNER
WATER TEMP INDICATOR WATER TEMPERATURE TELL-TALE
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEM MDP FR RR RADAR OBSTACLE DETECTOR
TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
FLOOR MAT FR + RR MATS
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL FULL FLOWER LEATHER ST WHEEL
AUDIO PACK AUXILIARY SOCKET 1 JACK SOCKET + USB
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Electrical
ALTERNATOR ISTT5 ALTERNATOR
HORNS HORN STANDARD
BATTERY BATTERY L3 760 SEALED(L3 760 VRLA 760 EN AGM)
STARTER MOTOR CLASS 6 STARTER MOTOR
SPECIAL LIGHTING DAYLIGHT RUNNING LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR "01" MINOR INDEX
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET 220V ACCESSORIES SOCKET + DOUBLE ACCESSORY
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 2 HF PLIP KEYS
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATE W/O ADDIT HOMOLOGATION PLATE
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
- x 1055
Beagle780 wrote: 03 Jun 2025, 10:28 Hi can I kindly get my data sheet. I need to identify my exact model for some new parts
Vehicle family C4 PICASSO
AS/RP N° 13401 FV 2 0218
Warranty Start Date 06/09/2013
Engine serial number 10 JBER 0102739
OPB K00U
BER e2*2001/116*0345*18
P4A 9801906899
General information
VEHICLE FAMILY C4 PICASSO
SILHOUETTE ESTATE - LEISURE
TRIM LEVEL MEDIUM MEDIUM PLUS
TRANSMISSION BVM6
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE WARP AND WEFT ANJOU + FYBER "5O"
UPHOLSTERY COLOUR "FX"
DEFINITION TO FOLLOW RANGE ACTIVITY
ROOF (EXT. ASPECT) BODY COLOUR ROOF
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
CAPACITY 1600 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
OPTIMISATION OF VEHICLE’S CONSUMPTION NORMAL FUEL CONSUMPTION OPTIMISATION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
VALVE PER CYLINDER 4
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
STOP AND START WITHOUT STOP AND START
TRANSMISSION BVM6
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE ROSKILDE 17-INCH WHEEL
CLUTCH HYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL DIAMETER 86
TYRE (SIZE, TYPE) NON-REINFORCED 215/50 R17 97W TYRE
WHEELS FITTED 6,5" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 2
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
REAR ANTI-ROLL BAR WITHOUT REAR ANTI-ROLL BAR
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 22.5
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITH ESP ASR+ SYSTEM
STEERING (OPERATION) ELECTR HYDRAUL POWER STEERING SLEEP MODE
Body fittings
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL + INTEGRATED
PAYLOAD NORMAL PAYLOAD
FINISHER (SELF-ADHESIVE) GLOSS BLACK REAR SURROUND TRIM
REAR SPOILER FITTING WITH RR UPPER DEFLECTOR
SIDE MOULDINGS (TYPE) GLOSS BLACK + BODY COLOUR
SIDE MOULDINGS (DIMENSION) THIN SIDE PROTECTORS
INDICATORS LUMINOUS SIGNATURE
SILL ILLUMINATION LAMP SILL ILLUMINATION
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING BONNET SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF STANDARD ROOF PNL
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR ACCESSORIES MIRROR AND HANDLE WITH BODY-COLOURED CHROME INSERT
SUN ROOF FIXED ROOF
BUMPER TRIM BUMPER WITH CHROME INSERT
WINDOW (TYPE) LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
Interior fittings
CIGAR LIGHTER WITH FRONT LIGHTER
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT 3 SEPARATE REAR SEATS (3 SLIDING)
SUPPLEMENTARY SEAT 2 PLACES SUPPLEMENT SEPAR SEATS
REAR SEAT ARMREST WITHOUT RR SEAT ARMREST
LUGGAGE COVER SCREEN
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING WITH AUTO RECIRCULATION HEATER MATRIX
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN MPH
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL HEADLAMP ILLUMINATION WITH PLIP
DASHBOARD EQUIPMENT STD FASCIA PANEL EQUIPMENT + INJECTED UPPER VP
INT. TRIM AND EQUIPMENT VARIATION LEATHER INTEROR EQUIPMENT FITTINGS
MISC. INT. LAMPS MAP READING LAMP + AMBIENT LIGHTING
WORK TABLE WITH WORK TABLE
LOAD SPACE TRIM W/O MAT
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL NEUTRAL FRONT PANEL
LOUDSPEAKER ASSEMBLY 2 FR SPEAKERS + 2 RR SPEAKERS
PASSENGER COMPARTMENT SOUNDPROOFING 7 KG BULKHEAD SOUNDPROOFING
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT SEAT ARMREST DRIVER ANT PASSENGER FRONT ARMREST
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
DISPLAY DISPLAY (RADIO+CLOCK,T°,CD)
SUPPLEMENTARY SEAT SEATBELT SUPPLY SEAT - INERTIA-REEL BELT
HEATING ELEMENT NON HEATED SEAT
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
PASSENGER AIRBAG PASSENGER AIRBAG
ADDITIONAL AIR CONDITIONING WITHOUT ADDITIONAL AIR CONDITIONING
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
STORAGE (DRIVING POSITION) CHROME TRIM UPPER STORAGE COMPARTMENT
RADIO RECEIVER RD45 MP3 RADIO CD - REMOTE DISPLAY
CRUISE CONTROL REGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
LOAD SPACE STORAGE WITHOUT STORAGE COMPARTMENT IN BOOT
CARPET CARPET MAT TUFTEE RASEE F470
INTERIOR PROTECTION WITHOUT INNER PROTECTION
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS SIDE BLINDS "ROW 2"
TRIM ADAPTATION LEATHER GAITER + KNOB CHROME INSERT
FLOOR MAT W/O CARPETMAT
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL 2 SPOKE LEATHER STEERING WHEEL WITH DECOR
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREEN WITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRROR INTERIOR CHILD MONITORING MIRROR
SUPPLEMENTARY HEATER WITHOUT ADDITIONAL HEATING
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff](L3 720 70AH EF 720 EN)
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
Miscellaneous
SPECIAL SPECIFICATION LIMITED EDITION 2011
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
EMERGENCY EQUIPMENT ANTI-BURSTING BOMB
SLAVE CONTROL UNIT BSI + COM FIXED HUB STEERING WHEEL
- x 1055
zaskar2097 wrote: 05 Jun 2025, 20:00 Hi! I'm thinking of buying a Citroen C5 X in the 1.2 Puretech 130hp EAT8 version. However the dealer can't seem to be very insightful of what equipment efectively comes with the car...(for example I'm still not sure whether the car comes with wireless phone charger and heated steering wheel...)
Thanks!!!
Vehicle family C5 X (E43 EIC)
AS/RP N° 16604 VD 1 0189
Warranty Start Date 30/12/2022
Engine serial number 10 XVAY 1847866
OPB 00PB
BER e9*2018/858*11066*02
P4A 9836493399
General information
VEHICLE FAMILY C5 X (E43 EIC)
SILHOUETTE CROSSOVER
TRIM LEVEL HIGH LOW
ENGINE EB2ADTS/EU63 1200 3 CYL PETROL
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR MAGNETIC BLUE PAINT
INTERIOR TRIM TYPE HALF GRAIN LEATHER/TEP "L7"
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) ATNG8
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EB TYPE ENGINE
TRIM LEVEL HIGH LOW
Fuel supply-Engine
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY 1200 CM3
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR 28DM2 EP: 18 BRAZED ALU
POWER VARIATION (ENGINE) POWER 96 KW 230 NM
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
FAN ONE 2-SPEED FAN 140 W DYNAMIC AIR SHUTTER RB45
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
STOP AND START WITH STOP AND START STARTER
FINAL DRIVE RATIO REAR AXLE GEARSET 15 X 61
WHEEL STYLE 19-INCH STYLE WHEEL
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 205/55 R19 97V TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED WHEELS FITTED 7 J19 RIM OFFSET 41
GEARBOX TYPE ATN8 TYPE GEARBOX
BRAKING ASSISTANCE IN REVERSE GEAR COLLISION WARNING - RCTA
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR THICKNESS 27500 NM/RAD
STEERING (OPERATION) LOW POWER SINGLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS WIDTH
WHEEL EMBELLISHER (STYLE) BLACK CENTRE CAPS+BLACK BOLTS DESIGN
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR+DIODE
EXHAUST TAILPIPE TRIM CHROME EXHAUST OUTLET TRIM
ENGINE BAY SOUNDPROOFING BULKHEAD SOUNDPROOFING+LOW+RH+ISOVAC+WHEEL ARCH
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER CHROME + BODY COLOUR FRONT/REAR BUMPER
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID VIDEO PARK 1
SPARE WHEEL SPARE WHEEL PRE-EQUIPMENT
SUN ROOF WITHOUT SUN ROOF
GLASS (APPEARANCE) TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTING FRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior fittings
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
BLIND SPOT DETECTION BLIND SPOT MONITORING + LANE CHANGE ASSIST
INTERIOR ALARM WITHOUT ALARM FORGET LIGHTS
RADIO TELEPHONE 2 SMARTPHONES
FRONT SEATBELT REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX+ADDITIONAL OUTLET
GRAB HANDLES FRONT + REAR + RETRACTABLE HANDLES
CONSOLE LONG CONSOLE + REAR AIR DUCT
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED GLOVE BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENT BLACK STRIP+METAL FILM DECOR
INSTRUMENT PANEL (CHARACTERISTICS) INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX
LOUDSPEAKER MOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCE TRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING
DRIVER SEAT CONTROL MANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROL MANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
STOWAGE BIN REFRIGERATED STORAGE BOX
SATELLITE NAVIGATION SYSTEM CONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBS ECO LED
TRAFFIC INFORMATION READER LKA STRUCTURAL EDGE
DISPLAY 12-INCH COLOUR HD TOUCHSCREEN DISPLAY
COURTESY MIRROR DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTREST DRIVER’S FOOTREST
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
FOOTWELL LIGHTING FOOTWELL LIGHTING WITH LED
WIFI WITHOUT WIFI
STORAGE (DRIVING POSITION) STORAGE COMPARTMENT BRAKED OPENING
RADIO RECEIVER ANALOGUE + DAB RADIO RECEIVER
CRUISE CONTROL ACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROL DRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
STORAGE (OTHERS) PLAIN STORAGE POCKET
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
OBSTACLE DETECTION SYSTEM FRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
RADIO FREQUENCY RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
SEATING ASSOCIATED VARIANT LOWER SEAT ASSOCIATED VARIANT
AUDIO PACK AUXILIARY SOCKET AUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR CLASS 15 UHEA
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR STTD STARTER
ELECTRICAL EQUIPMENT (SUPPLY) LEOCH BATTERY
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING NEA R1
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Miscellaneous
CONDENSER (SPECIFICATIONS) CONDENSER 23.5 DM2 THICKNESS 16 UPPER FLANGE
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
SIDE IMPACTS UPPER REINFORCED SIDE IMPACT PROTECTORS
REFRIGERANT AIRCON FLUID 1234 YF
zaskar2097
wheeler wrote: 06 Jun 2025, 16:15zaskar2097 wrote: 05 Jun 2025, 20:00 Hi! I'm thinking of buying a Citroen C5 X in the 1.2 Puretech 130hp EAT8 version. However the dealer can't seem to be very insightful of what equipment efectively comes with the car...(for example I'm still not sure whether the car comes with wireless phone charger and heated steering wheel...)
Could anyone please provide me with the factory build sheet? VIN is VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].
Thanks!!!
Thanks a bunch wheeler!
zaskar2097
Any chance of getting the build sheet also for the VIN VR7**************[VIN obfuscated, can be read by forum staff]?
It's another possibility on the table (another Citroen C5X), and being a 2024 unit I'm wondering if it might be a safer bet than the 2022 MY wet belt one... Also I'm convinced the servicing interval is different.
Thanks in advance!
Thanks in advance!
- x 1055
Características do veículozaskar2097 wrote: 06 Jun 2025, 19:14 Any chance of getting the build sheet also for the VIN VR7**************[VIN obfuscated, can be read by forum staff]?
Thanks in advance!
Modelo C5 X (E43 EIC)
NºAPV/PS 17309 VD 1 0104
Data de Inicio da Garantia 22-08-2024
Número de série do motor 10 TMAG 0089844
OPB 00PB
NRE e9*2018/858*11066*08
P4A 9836493399
Informações gerais
GÉNERO DE PRODUTO VEÍCULO PARTICULAR
MARCA COMERCIAL/TIPO ÓRGÃO CITROEN
LINHA DE PRODUTO C5 X (E43 EIC)
SILHUETA CROSS BERLINA
ACABAMENTO ALTO BAIXO
MOTOR EB2ADTS UE64 1,2 L A GASOLINA
TRANSMISSÃO CVA 8 VELOCIDADES TIPO STT
TIPO PINTURA TIPO REVESTIMENTO EXT METALIZADO VERNIZ
COR DE CARROÇARIA COR PRETO PERLA NERA
TIPO REVESTIMENTOS INTERIORES MEIO COURO GRÃO/TEP "L7"
COR DO REVESTIMENTO "FZ"
CAIXA VELOCIDADES (CARACTERÍSTICA) ATNG8
ANIMAÇÃO TRANSFORMAÇÃO SEM TRANSFORMAÇÃO
DEFINIÇÃO FUTURA GAMA INICIAL
MOTOR (TIPO) MOTOR TIPO EB
TEJADILHO (APARÊNCIA EXTERIOR) TEJADILHO COR DA CARROÇARIA
Características veículo
Alimentação motor
BATERIA DE TRAÇÃO SEM BATERIA DE TRAÇÃO
COMBUSTÍVEL SEM CHUMBO 95 QUALIDADE A/B/E/E+
ANTI-POLUIÇÃO (MOTOR) ANTIPOLUIÇÃO DO MOTOR EURO 6,4
CILINDRADA 1200 CM3
ISOLAMENTO RESERVATÓRIO COMBUSTÍVEL SEM ISOLAMENTO DEPÓSITO
MOTOR ARREFECIMENTO RADIADOR 28DM2 EP: 18 ALU SOLDADO
REAQUECIMENTO CIRCUITO GÁS CÁRTER SEM AQUECIMENTO CIRCUITO GASES CÁRTER
VARIAÇÃO POTÊNCIA (MOTOR) POTENCIA 96 KW 230 NM
AUTO-DIAGNÓSTICO EOBD COM AUTODIAGNÓSTICO "OBD"
DISPOSITIVO (ANTI-POLUIÇÃO) SEM DISPOSITIVO ANTIPOLUIÇÃO
ANTI-POLUIÇÃO TÉCNICA VEÍCULO ANTIPOLUIÇÃO TÉCNICA VEÍCULO EURO 6.4
VENTILADOR 1 VENTILADOR 2 VELOCIDADES 140 W AERO BORBOLETA DINÂMICA RB45
VARIANTE ASSOCIADA INJECÇÃO SISTEMA INJECÇÃO DELPHI
CADEIA DE TRAÇÃO CADEIA DE TRAÇÃO TÉRMICA
FILTRO RESERVATÓRIO FILTRO RESERVATÓRIO INTERIOR
PÁRA E ARRANQUE (STOP AND START) COM STOP AND START MOTOR DE ARRANQUE
Caixa de velocidades Transmissão
BINÁRIO RELAÇÃO BINÁRIO DE DIFERENCIAL 15 X 61
ESTILO RODA ESTILO RODA 19 POLEGADAS
EMBRAIAGEM SEM EMBRAIAGEM
JUNTA LADO DA RODA JUNTA LADO DA RODA RZ17.5 D26
JUNTA LADO DA PONTE JUNTA LADO EIXO JB2T D26
JANTE/ PNEU DIMENSÃO MONTAGEM PNEU 19 POLEGADAS
PNEU (DIMENSÕES, TIPO) PNEU 205/55 R19 97V
RODAS MOTRIZES 2 RODAS MOTRIZES
RODAS MONTADAS RODAS MONTADAS 7J19ET41
RODA (TIPO) MONTAGEM RODA EM LIGA LEVE 1
CAIXA DE VELOCIDADES TIPO CAIXA TIPO ATN8
Suspensão Direcção Travões
ASSISTÊNCIA À TRAVAGEM EM MARCHA-ATRÁS ALERTA DE COLISÃO – RCTA
BARRAS ESTABILIZADORAS TRS BARRA ESTABILIZADORA TR DUREZA 25000 NM/RAD
BARRA ESTABILIZADORA TRS BARRA ESTABILIZADORA FR DUREZA 27500 NM/RAD
TRAVÃO TIPO DISCOS FR VENTILADOS/TAMBORES TR
SUSPENSÃO SUSPENSÃO NORMAL
SUSPENSÃO (TIPO ARQUITECTURA) SUSPENSÃO METÁLICA
CONTROLO DINÂMICO DE ESTABILIDADE COM SISTEMA ESP
VARIANTE ASSOCIADA TRAVÕES ESP BOSCH 9.3 HSM
DIRECÇÃO (FUNCIONAMENTO) DIREÇÃO ASSISTIDA ELÉTRICA DE PINHÃO ÚNICO LOW POWER V3 VC3
PEDAIS (TIPO) PEDAIS STANDARD SIMPLES
Carroçaria Equipamentos
GANCHO DE REBOQUE SEM GANCHO DE REBOQUE
AVISADORES BUZINA COM MELODIA
REVESTIMENTOS LATERAIS (DIMENSÃO) PROTECTORES LATERAIS LARGOS
TAMPÃO DE RODA (ESTILO) ESTILO TAMPÕES CENTRO PRETO + PARAFUSO PRETO
PROTECÇAO DEBAIXO DA CARROÇARIA PROTEÇÃO DEFLECTOR LONGO SOB A SUPERFÍCIE INFERIOR DIANTEIRO DIREITO DIANTEIRO ESQUERDO
COMPLEMENTO PROTECÇÃO (SOB MOTOR) SEM PROTECÇÃO COMPLEMENTAR SOB MOTOR
FUNÇÃO COMPLEMENTAR RETROVISOR EXT. RETROVISOR EXTERIOR REBATÍVEL ELÉTRICA+DÍODO
EMBELEZADOR SAÍDA DE ESCAPE EMBELEZADOR SAÍDA DE ESCAPE CROMADO
INSONORIZAÇÃO LADO MOTOR INSONO TAB + INF + D + ISOVAC + PASS RODA
VIDRO PÁRA-BRISAS (TIPO ) VIDRO PÁRA-BRISAS AQUECIDO
LIMPA-VIDROS FRT LIMPA-VIDROS FR COM SENSOR DE CHUVA
VIDRO TEJADILHO SEM VIDRO TEJADILHO
PÁRA-CHOQUES PC FR/TR COR CARROÇARIA + CROMADO
PORTA-BAGAGEM MONTAGEM SEM PORTA-BAGAGENS
FAROL DE NEVOEIRO LUZES DE NEVOEIRO DE LED + LUZES DE CURVA
AJUDA VISUAL PANORÂMICA VISIO PARK 1
RODA SOBRESSALENTE SEM RODA SOBRESSALENTE
TECTO DE ABRIR SEM TECTO DE ABRIR
VIDRO (ASPECTO) VIDRO COLORIDO + FUMADO TRS
ACESSO E MOTOR DE ARRANQUE MÃOS LIVRES ACESSO DT + MALA + ARRANQUE SEM CONTACTO
Equipamento interior
ALARME ANTI-ROUBO SEM ALARME ANTI-ROUBO
APOIO DE CABEÇA FRT ENCOSTO DE CABEÇA FR REGULÁVEL 2 VIAS
ASSENTO TRS BANCO TRASEIRO MONO FX + COSTAS 40/20/40 REB
DETEÇÃO ÂNGULO MORTO CONTROLO DOS ÂNGULOS MORTOS + ASSIST MUDANÇA DE VIA
APOIO DE BRAÇOS ASSENTO TRS COM APOIO DE BRAÇOS DO BANCO TRASEIRO
ALARME INTERIOR SEM ALARME INTERIOR
RÁDIO TELEFONE 2 SMARTPHONES
CORTINA BAGAGENS PARTE MÓVEL
CINTO DE SEGURANÇA TRS CINTO SEG TRAS 3 ENROLADORES 3 PTS + LUZ COLOCAÇÃO
CINTO DE SEGURANÇA FRT ENROL + ALARME CINTO + LIM ACTV CDC/CS PSG
AR. COND. (Tª AMBIENTE) PAÍSES FRIOS
AR CONDICIONADO COM AEROTERMO + SAÍDA COMPLEMENTAR
TRANCAMENTO PARA CRIANÇAS TRANCAMENTO PARA CRIANÇAS ELÉCTRICO TRS
GRADUAÇÃO VELOCIDADES GRADUAÇÃO VELOCIDADES EM KM/H
COMODIDADES (PEGAS) PUXADORES DIANTEIROS + TRASEIROS + RETRÁTEIS
CONSOLA CONSOLA LONGA + CONDUTA AR TRS
LADO DE CONDUÇÃO (POSTO DE CONDUÇÃO) VOLANTE DO LADO ESQUERDO
MIRROR LINK COM MIRROR LINK
ILUMINAÇÃO COMPARTIMENTO ARRUMAÇÃO ILUMINAÇÃO PORTA-LUVAS LED
ILUMINAÇÃO MALA VOLUME DE CARGA CDO AUTO-ILUMINAÇÃO MALA + VOLUME CARGA LED
EQUIPAMENTO TABLIER FRISO PRETO + DECORAÇÃO PELÍCULA MADEIRA
QUADRANTE (CARACTERÍSTICAS) QUADRO DE BORDO COM ECRÃ DE MATRIZ
ALTIFALANTE MONTAGEM 2 ALTIFALANTES FR + 2 TWEET FR
MOTOR VENTILAÇÃO ADICIONAL SEM VENTILADOR ADICIONAL
FILTRO DE PÓLEN COM FILTRO DE PÓLEN+CARVÃO ATIVO+FILTRO DE PARTÍCULAS FINAS+GÁS
ASSISTÊNCIA DE CONTROLO DA TRAJETÓRIA ASSIS CONTR TRAJ/CENTR FAIXA AJUDA À PERM DA TRAJ DO VEÍC NA VIA DE CIRC (LPA)
REGULAÇÃO ALTURA DO ASSENTO FRT PASSAGEIRO ELEVAÇÃO ASSENTO DIANT PASSAGEIRO REGULAÇÃO PARALELA
COMANDO ASSENTO FRT CONDUTOR COMANDO ASSENTO CONDUTOR MANUAL
COMANDO ASSENTO FRT PASSAGEIRO COMANDO DO BANCO DO PASSAGEIRO DIANTEIRO MANUAL
REGULAÇÃO ASSENTO FRT CONDUTOR COSTAS DO BANCO RECLINÁVEL APOIO LOMBAR DO CONDUTOR
REGULAÇÃO ASSENTO FRT PASSAGEIRO REGULAÇÃO ASSENTO DIANT PASSAGEIRO COSTAS DO BANCO RECLINÁVEL
CD SEM MONTAGEM CD
CAIXA DE ARRUMAÇÃO CAIXA DE ARRUMAÇÃO REFRIGERADA
SISTEMA DE NAVEGAÇÃO SISTEMA DE NAVEGAÇÃO CONETÁVEL
LÂMPADAS DOS FARÓIS ECO LED
LEITOR INFORMAÇÃO TRÁFEGO LKA BORDO ESTRUTURAL
ECRÃ ECRÃ 12 POLEGADAS COR HD TÁTIL
ESPELHO DE CORTESIA ESPELHO OCULTÁVEL CONDUTOR+PASS COM ILUMIN LED
APOIO PARA PÉS APOIO PÉ CONDUTOR
ENCHIMENTO ALMOFADA COBERTURA COM SENSOR DE DETEÇÃO DE PASSAGEIRO
MONTAGEM APOIO DE CABEÇA TRS MONTAGEM 3 APOIOS-DE-CABEÇA TR
NAPPA DE AQUECIMENTO BANCO AQUECIDO CONDUTOR + PASSAGEIRO R1
AIRBAG LATERAL FRT SACO AIRBAG LAT TÓRAX BACIA FR+INT+DUR FR/TR
ILUMINAÇÃO PARTE INFERIOR HABITÁCULO ILUMINAÇÃO DO ESPAÇO PARA OS PÉS COM LED
NEUTRALIZAÇÃO AIRBAG NEUTRALIZAÇÃO MANUAL AIRBAG
FAROL CORRECTOR EM ALTURA REGULAÇÃO MANUAL À DISTÂNCIA DOS FARÓIS
WIFI SEM WIFI
ESPAÇOS DE ARRUMAÇÃO (POSTO CONDUÇÃO) PORTA-LUVAS ABERTURA COM TRAVÃO
RECEPTOR RÁDIO RECETOR DE RÁDIO ANALÓGICO + DAB
REFRIGERAÇÃO REFRIGERAÇÃO AUTOMÁTICA
REGULADOR VELOCIDADES ACC3 DECEL0 + ACCEL0
REG. EM ALTURA DO ASSENTO FRT CONDUTOR ELEVAÇÃO DO CONDUTOR REGULAÇÃO DE ALTURA
RETROVISOR INTERIOR RETROVISOR INTERIOR ELETROCROMADO FRAMELESS
REGULAÇÃO CLIMATIZAÇÃO/TEMPERATURA REFRIGERAÇÃO AUTOMÁTICA BI-ZONA
ESPAÇOS ARRUMAÇÃO (OUTROS) BOLSA DE ARRUMAÇÃO CHEIA
ESPAÇO ARRUMAÇÃO VOLUME DE CARGA CINTA LATERAL MALA + REDE
ENCHIMENTO ASSENTOS TRASEIROS SEM DETEÇÃO PASSAGEIRO TR
SINTONIZADOR RÁDIO DUPLO SINTONIZADOR DE RÁDIO
DETECÇÃO OBSTÁCULO DETETOR OBSTÁCULOS RADAR FR/TR + TRAJETÓRIA
ALCATIFA SEM TAPETE
FREQUÊNCIA RÁDIO FREQUÊNCIA RÁDIO AMT6_FMT4-50-DIAFTAPSTMC_DABT1
COMANDO TRANCAMENTO FECHO TRANCAMENTO SIMPLES + AUTOMÁTICO
VOLANTE VOLANTE EM COURO
VARIANTE ASSOCIADA ASSENTO VARIANTE ASSOCIADA BANCO BAIXO
AIRBAG JOELHOS CONDUTOR SEM AIRBAG JOELHOS CONDUTOR
TOMADA AUXILIAR PACK AUDIO TOMADA AUXILIAR CONJUNTO AUDIO 1 USB TIPO C
CAIXA TELEMÁTICA CAIXA TELEMÁTICA AUTÓNOMA
Electricidade
ALTERNADOR ALTERNADOR CLASSE 15 UHEA
BATERIA (MONTAGEM) STANDARD
BATERIA BATERIA L3 760 70AH EFBC 760 EN EFBC
MOTOR DE ARRANQUE MOTOR DE ARRANQUE STTD
FREQUÊNCIA TELECOMANDO TRANCAMENTO FREQUÊNCIA TELECDO TRANC 433,92 MHZ HETERODYNE
EQUIPAMENTO ELÉCTRICO (ACESSÓRIO) BATERIA LEOCH
CARREGADOR BATERIA SEM CARREGADOR INTEGRADO
MULTIPLEXAGEM NEA R1
CARREGAMENTO VEÍCULO ELÉCTRICO SEM TOMADA RESPONSABILIDADE VEÍCULO
ACENDIMENTO LUZES ACENDIMENTO LUZES AUTOMÁTICAS+COMUTAÇÃO AUTOMÁTICA
Marcas de equipamentos
Diversos
CRITÉRIO VARIÂNCIA, CLIENTELA CONCEPÇÃO STANDARD
MODIFICAÇÃO EM CURSO AM 2.ª MODIFICAÇÃO MENOR
CONDENSADOR (CARACTERÍSTICAS) CONDENSADOR 23,5DM2 ESPESSURA 16 BRIDA ALTA
ATMOSFERA ATMOSFERA NORMAL
PLACA CONSTRUTOR PLACA CONSTRUTOR UNIÃO EUROPEIA + NRE
TUBOS DE REFRIGERAÇÃO TUBOS DE REFRIGERAÇÃO TECNOLÓGICA IHX
TOMADA ESCUTA RÁDIO TOMADA DE ACESSÓRIO SIMPLES
LADO CIRCULAÇÃO CIRCULAÇÃO À DIREITA
CHOQUES LATERAIS COLISÕES LATERAIS REFORÇO SUPERIOR
LÍQUIDO REFRIGERAÇÃO LÍQUIDO DE REFRIGERAÇÃO 1234 YF
EQUIPAMENTO AUXILIAR KIT ANTI-FURO
ROLAMENTO BOA ESTRADA
VIGILÂNCIA VELOCIDADE SEM VIGILÂNCIA VELOCIDADE
zaskar2097
Thanks wheeler! Seems to be the same engine, no ideia if the belt is still the same or not.
Could you get me the service schedule for these (thinking back, should have asked before, sorry)? I know for sure older generation had a different schedule than the latter.
(2022 unit is VR7**************[VIN obfuscated, can be read by forum staff] and the 2024 is VR7**************[VIN obfuscated, can be read by forum staff])
- x 1055
zaskar2097
Thanks again wheeler!
Engine models and service schedules seem almost the same, though one is Euro 6.3 and the other Euro 6.4...
UfoNlo
Howdy! Any chance I could get some help with identifying what engine my 2018 C3 MK3 has?
- x 1941
The 6th, 7th and 8th characters are your engine code and I can see that it is HMZ. According to an AI response-
The Peugeot engine with the code HMZ is a 1.2L VTi petrol engine, part of the PureTech family, with 82 horsepower (60 kW) and a three-cylinder design. It was used in various PSA models like the Peugeot 208 and Citroën C3 from approximately 2012 to 2019.
Engine Type: 1.2L VTi petrol engine
Power: 82 horsepower (60 kW)
Cylinders: 3
Engine Code: HMZ, often referred to as EB2F
Vehicle Applications: Used in models such as the Peugeot 208, 2008, and Citroën C3, typically for model years 2012–2019
Cylinders: 3
- x 1055
C3 (B618) 5 DOOR HATCHBACK 1.2 i VTi 82 (EB2F Euro 6) BVM5UfoNlo wrote: 11 Oct 2025, 02:52 Howdy! Any chance I could get some help with identifying what engine my 2018 C3 MK3 has?
ENGINE EB2F 60KW INJECTION
FUEL SUPPLY INJECTION
FUEL FILLER CAP FUEL CAP WITH LOCK
EMISSIONS STANDARD (ENGINE) EURO 6.1 ENGINE EMISSION CONTROL
CAPACITY 1200 CM3
CATALYTIC CONVERTER 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
FUEL TANK FUEL TANK WITHOUT LOCATING TAB
COOLING MOTOR 16 THICK RADIATOR - 16 DM2 BRAZED ALU WITHOUT MEC
POWER VARIATION (ENGINE) POWER 60 KW 118 NM
VEHICLE TECHNICAL DEPOLLUTION EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 100W AERO 2-SPEED FAN
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT VALEO INJECTION SYSTEM
