C4 Grand Picasso died on me!
ProfessorPike
Stopped at traffic lights, engine cut out, would not restart! Much chaos in Gloucester due to me! A nice guy in a toyota towed me across and out of the way.
RAC guy said the engine speed was 0. He thinks its this sensor here Engine speed sensor, is this also the crankshaft sensor? Im looking to buy one and fit it asap!!
Any help appreciated!
moizeau
- x 423
Re: C4 Grand Picasso died on me!
It is but I didn't think they caused an engine to cut out, just not start.
Pete
PaulC5
- x 716
See if it will restart once the engine has cooled down - this can be a sign the sensor is failing but eventually will not let the engine run at all instead of just when it is hot. I replaced the crank sensor on a friends Corsa and that would cause the engine to stop when hot but run again once cold. Fitting a new part fixed it. If it does fail there might not be a fault code since the engine needs to run to give one.
- x 1060
That's the camshaft sensor your thinking of.moizeau wrote: 30 May 2025, 15:50 It is but I didn't think they caused an engine to cut out, just not start.
If the ECU looses the signal from the crank sensor the engine will stop immediately.
Yes, that is the Crank/engine speed/TDC sensor in the picture.
- x 1499
What engine? Really need some diagnostics with live data to pin point the issue.
ProfessorPike
2.0l HDi.RichardW wrote: 30 May 2025, 16:18 What engine? Really need some diagnostics with live data to pin point the issue.
RAC said crankshaft sensor, but he said it was the one he pointed out on the picture.
*edit* I've just been out and tried to start it. It made some less than pleasant noises cranking and then fired up!
Looking on Amazon as i'd like to get this done this weekend! GSF dont have it and neither do Eurocar parts!
This is the GSF one!
https://www.gsfcarparts.com/parts/elect ... aft-sensor
This one on amazon, it says it fits!
https://www.amazon.co.uk/febi-bilstein- ... .0+HDI+138
- x 8166
I'm pretty sure the Citroen number for your crankshaft sensor is 1920GJ so if the part quotes that number I think it will fit!!
- x 1499
That doesn't sound good (no pun!) - crank sensors do occasionally go on this engine; the bad noises are more concerning... HP pumps can give up the ghost.ProfessorPike wrote: 30 May 2025, 16:35
ProfessorPike
It was engine starting sounds, but they were intermittent and sounded angry!!RichardW wrote: 30 May 2025, 18:07That doesn't sound good (no pun!) - crank sensors do occasionally go on this engine; the bad noises are more concerning... HP pumps can give up the ghost.ProfessorPike wrote: 30 May 2025, 16:35
- x 1499
If no crank signal it will crank a second or so then stop, then try again, then stop.
Note, don't buy a cheap one off Amazon / eBay - they are likely to be worse than useless!
ProfessorPike
Too late!!RichardW wrote: 31 May 2025, 08:54 If no crank signal it will crank a second or so then stop, then try again, then stop.
It's a fedi bilstein. What brand should I be going for?
I'll stick it on and look to source a decent replacement ASAP.
- x 8166
I use febi bilstein parts a lot and find them t be fine!
ProfessorPike
I picked one mod range in price!! The cheapest was 11 quid i think!
- x 5679
Again, the main problem can be counterfeit parts.
I needed a lambda sensor for my Mazda. £50 from Temu, £600 from Mazda.
Fortunately? the car was written off and saved me the cost
- x 1499
Febi probably OK, if that's what it actually is - as Steve says, a lot are counterfeit cheap Chinese knockoffs. In the case of a crank sensor it will probably work or not, a lot of the more complex stuff sort of works, but sends erroneous / confusing messages which upset the ECU. OEM is probably Bosch or Siemens, but these can be fakes as well. Minefield!
