- x 2336
LED bulb (replacing CFL energy bulb)
Done
Done
- x 8085
Looks great Matt! Now I realise where the stripes came from!
- x 2336
Yes, when I bought these - at least a decade ago - there was an "unarmoured" version, missing those three horizontal bars. I guess I saved myself a tiny amount of polishing there!mickthemaverick wrote: 04 May 2025, 17:12 Looks great Matt, Now I realise where the stripes came from!![]()
Working up the confidence to tackle the headlights, maybe tomorrow...
- x 2336
Room for improvement, definitely!
- x 8085
They will come up great, I did mine with 400, 600, 800, 2k and 3k for the best finish!!
- x 2336
Ah good to know. I've got (40, 60, 80, 120, 240) 400, 800 - I think, 1200 and possibly some 2000 grit if memory serves. Bracketed variants included to complete the list rather headlamp attacking options, hopefully obviously!mickthemaverick wrote: 04 May 2025, 17:47 They will come up great, I did mine with 400, 600, 800, 2k and 3k for the best finish!!![]()
- x 2336
Headlamp polishing deferred, plumbing job first.
Kitchen sink does not drain well.
Current low profile trap thought to be the culprit. A big depth of seal isn't needed (why will become apparent shortly)
This trap was selected to give a meaningful drawer capacity.
Now swapping to a shallow bath trap. First test
- x 2336
Became obviously the trap isn't fully responsible
Fair to say image really does not convey the aroma!
- Spoiler: show
- x 8085
Hmmm methinks a change of washing up routine is warranted!!
Onlinemyglaren
- x 5671
Do it in the garden and chuck the waste water over the fence.mickthemaverick wrote: 05 May 2025, 12:31 Hmmm methinks a change of washing up routine is warranted!!![]()
- x 8358
Or water your garden with it... 'Grey' water is fine for that and it might even contain nutrients the plants will appreciate...myglaren wrote: 05 May 2025, 12:34Do it in the garden and chuck the waste water over the fence.mickthemaverick wrote: 05 May 2025, 12:31 Hmmm methinks a change of washing up routine is warranted!!![]()
The state of your waste pipe Matt!!! And I've never seen those low-profile traps although I do like the look of them... My favourite is a bottle trap*
* Gosh, here am I admitting to having a favourite sort of trap - how sad is that? It's a bit like having a favourite spatula, although having said that, I have one of those too
- x 2336
As our shower, a "deluge" type is fairly water inefficient, in the past we had hot summers and sought to use a bit of garden greywater by the following "easy" method:CitroJim wrote: 05 May 2025, 17:24Or water your garden with it... 'Grey' water is fine for that and it might even contain nutrients the plants will appreciate...myglaren wrote: 05 May 2025, 12:34Do it in the garden and chuck the waste water over the fence.mickthemaverick wrote: 05 May 2025, 12:31 Hmmm methinks a change of washing up routine is warranted!!![]()
- have shower with the bath plug down.
- retrieve hosepipe (tied outside bathroom window)
- instigate syphon (quick 2 second holding end of hose over bath tap connection usually sufficiently filled hose to a level below bath water level hence setting off the symphonic action)
- empty bath 90% by keeping end of hose below surface.
- discharged water accumulated into a "spare" wheelie bin. About half a bin full per bath.
- following day: water plants /grass with watering can dunked into wheelie bin.
The weather over roughly the past decade hasn't needed the above solution repeat since! We've had some good weather early in the year - I do wonder if this year could get us into hosepipe bans and need of water conservation techniques once more???
Oh it was truly grim! Wish I could turn my sense of smell off for the afternoon!!The state of your waste pipe Matt!!! And I've never seen those low-profile traps although I do like the look of them... My favourite is a bottle trap*![]()
It's one of these:
https://www.toolstation.com/espace-extr ... -12/p87482
I rate it. Interestingly there are a lot of Toolstation reviews suggesting poor sealing. Didn't have that issue with mine. Think it was bought long ago enough as to be before Toolstation had reviews!
The first step is realising you have a problem!
* Gosh, here am I admitting to having a favourite sort of trap - how sad is that? It's a bit like having a favourite spatula, although having said that, I have one of those too![]()
Still cementing around the pipe to do, but otherwise here is the finished job: Happy with that, no leaks. Drains a bit faster
Grey 308 washed, no headlamp polishing as yet.need to look if I've any smoother wet and dry grades
- x 2336
Just to note: our 1929 house is old enough to have only "combined" sewers - no separate Surface Water provision, hence why kitchen roof's drainpipe and kitchen sink can be fed into the same gully.
- x 2336
Oh, and moment of (slight) euphoria from earlier:
This length of white pipe, I used for the bit passing through the wall. White matches the trap so when laid on the kitchen floor for whatever reason it is pleasing to the eye....
Anyway, it's been "saved for future use" in the garage for at least a decade. This little offcut is the waste from today's use. Ahhh, so it was worth saving it all that time !!!
- x 3566
MattBLancs wrote: 05 May 2025, 18:35
I was watching the always informative latest 'Harry's Farm' Youtube and he reckons his bit of Oxfordshire has had less rain this Spring than we had in the Spring of 1976...... not that that tells you much though. The Autumn / Spring total rainfalls for a lot of areas are worryingly down on averages at the moment though.
....and..... much more importantly and tellingly - the Oak was out before the Ash down here
