As an 84 year old male who has tinkered with cars for decades, this to me sounds a 'stupid question' but safety first I say, so here goes.
Where exactly is the Negative Terminal on my 2011 C3 Picasso VTR Plus HDi 1.6 Diesel. 58k - Please.
I would have gone for Pic No 3 myself.
I will shortly be removing the 'under bonnet Fuse box' plugs to attempt a clean of the Orange Plug lighting contacts which, due to water ingress have faulted in the connection to the o/s side lamps.
I will wait for about 30 minutes before working on the Fuse Box, as instructed so residual power has died down and then I believe it will be safe to work on.
Thank you Robert.
Location of Negative Terminal
- x 1056
Re: Location of Negative Terminal
pic 3 is the negative jump start point, not the battery terminal once you disconnect the positive terminal (with the exception of the airbag system) you can work on the car immediately.
The negative terminal is under the plastic cover. Disconnecting the positive alone should be fine, just protect it from accidental reconnection
Retired TD
- x 8
Many thanks to your good self wheeler, I may have misheard instructions that I should remove the 'Negative' terminal only hence my question on this Forum which you have kindly corrected me. Always wise to double check I always say. Kind regards...
- x 1056
It would be very difficult to even remove the negative terminal without first removing the positive
Moey79
Hey
I have a similar issue i need to change my wiper motor but google etc says i must remove negative connection or i will damage electrics etc am i ok to remove positive only
- x 1941
Yes if you follow the precautions given above,
Argos69
- x 59
Many years ago I "successfully" put a spanner across a car battery terminals - never again!
My trick is to undo the battery terminal (positive terminal in this case) and put it in a rubber glove.
Always works!
Always works!
2010 Land Rover Freelander 2 HSE Automatic
2013 Citroen C5 Tourer 2.2HDi Exclusive
2017 Citroen Berlingo Multispace Flair 120 Gone!
2012 Citroen C5 Tourer 1.6HDi 6 Speed (sort of auto!) Gone!
2012 Citroen Berlingo Enterprise 1.6HDi Van Gone!
2001 Range Rover 4.6 Vogue Gone!
