106 Graduate 1.5
Cooper1987
106 Graduate 1.5
Unread post by Cooper1987 »
Good evening, new to the group and Peugeot ownership. Picked my 106 up as a back up (that I needed sooner than I thought!) Now it's my daily I love it!
However I have some problems/issues I hope you can help?
Gearbox, started grinding in 2nd, I assume this is a worn synchro?.... looking for another Gearbox to swap with and I'm looking for the right gearbox code?
(Unfortunately I don't have a set of ramps to get under it at the moment)
Someone in Ebay did think this would fit 20CC57 gearbox for CITROEN AX 1.5 DIESEL 1987 95705
My second problem; I'm looking at getting the injectors replaced, would anyone have a set I'd be able to get serviced/tested before I fit them?
As I mentioned its my daily so hence the reasoning behind swapping parts, etc
Any advice/tips appreciated.
x 1053
Re: 106 Graduate 1.5
Unread post by wheeler »
What is your VIN?
Why do you want to replace the injectors?
Cooper1987
The vin is VF3**************[VIN obfuscated, can be read by forum staff].
I'm not 100% think one might be faulty, it's missing on idle, it also smokes a bit at tick over, even when it's warm?
The thing wasn't touched for a while before I had it, do I'm working through things as and when I can.
x 1053
Gets a bit confusing, there are 2 gearbox part numbers (plus an exchange box) listed for this car by the VIN.
Casing numbers shown below.
x 1996
Unread post by Stickyfinger »
Go the RAce car with this.... :) https://www.satchellengineering.co.uk/p ... uential-2/
However, some good info here
http://www.saxperience.com/forum/showth ... p?t=470467
Same engine in a Saxo should provide the same gearbox I would think..... they are the same car really
PaulC5
x 689
Unread post by PaulC5 »
If you are going to fit another old gear box then that could also have wear in it. Why not replace the synchromesh in your existing one ?
Oldpug
x 94
Unread post by Oldpug »
You will have the MA gearbox. They all will bolt on and fit, but some have different ratios, different gear linkage, and some have different driveshafts?
If you want a second hand box that’s the same as yours, best talk to Dean Hunter www.peugeotparts.co.uk.
Mind you the most reliable route would be to remove the box and take it to a gearbox specialist for repair. They are a very simple box to pull apart, if it’s just a gear and synchro, won’t be very expensive.
Cooper1987
Cheers for all the info, much appreciated!
Yes, I had seen the Satchel box, unfortunately I don't think I can justify that just yet! 😂
As for the second hand box, rather than a rebuild, as I'm working on tight time frames, swapping the box and rebuilding at my leasure seemed the best option (just not necessarily the most cost effective)
Cheers again, I must say, out of the forums I've used in the past this has been definitely the most useful!
