Fitting fog lights to a 106
leadsled
Unread post by leadsled »
Hi,
I want to install fog lights to a Peugeot 106 that didn't originally have them. I've got the fog lights, a GTI wiring loom, and the stalk with the front fog light function. I'm competent with the wiring however I want to know if the car already has a fog light relay installed (like some of the 306's did despite not having fog lights). Can anybody tell me where the relay for the front fogs is located in the car?
Thanks.
x 1053
Re: Fitting fog lights to a 106
Unread post by wheeler »
I used to have a 106 Quicksilver that had factory front 'fogs' that weren't even fogs as they only came on with the full beam, no switch on the stalk for front fogs.
According to Autodata this should be the front fogs relay
leadsled
Thank you for the diagram. Are those relays located behind the glove box?
