Part number request exhaust system
martin_b
(Donor 2022)
x 8
Unread post by martin_b »
Please help me with the part number for the flexible tube in front of the DPF on my C4 Cactus 1.6 BlueHDI.
Should look something like this:
wurlycorner
x 271
Re: Part number request exhaust system
Unread post by wurlycorner »
If people can’t find the oem part number for you, have you tried an aftermarket exhaust manufacturer catalogue (and can then cross reference elsewhere if needed)?
Eg
http://www.euroflo-uk.com/Catalogue.aspx
Iain
CX DTR T2 Safari (silver)
martin_b
(Donor 2022)
x 8
No, I hadn't tried that. Thanks for pointing me in that direction. It seems, though, that the flexible tube I'm looking for is part of the DPF. Strange, since my local mechanic has it available from his supplier - just that they can't deliver it for the time being....
x 1936
The drawing you posted doesn't show the flexy as a separate item at all. Is there another drawing available?
martin_b
(Donor 2022)
x 8
Nope, all I could find. Hence me asking for a part number and a reply from an admin 😊
x 2941
Some in the Bosal catalogue, I haven't looked far but if you can get the online catalogue up maybe you can find it. example here:
https://www.bing.com/shop/productpage?q ... 0D6B86DE3A
https://www.bing.com/shop?q=bosal+exhau ... cc=0&ghpl=
x 1056
Unread post by wheeler »
Not listed as a separate part from the dealer, It's part of the DPF I'm afraid
martin_b
(Donor 2022)
x 8
Thanks wheeler. So it seems. I found a replacement flex pipe that can be welded to the DPF which I will fit instead. It's a repair kit for this exact vehicle.
