white exec wrote: 22 Jun 2021, 17:46 Sorry, not following you.
Do you have the correct code, and its input procedure?
To obtain the code, if you need it, this site works:
https://www.radio-code.co.uk/PU1561A-Ci ... guide.html
Site also contains code entry instructions.
Input the unit's 14-digit full serial number, pay the small fee, and get the code.
Band needs pressing for 5secs+.
Xantia Locked Radio (PU-1561A)?? Need help
Renanek9
- x 4
Re: Xantia Locked Radio (PU-1561A)?? Need help
Xantia Ph 2 Activa V6 - 7681CJ / VH000121
- x 1751
Sorry to have to say this, but you really do need to be a tad more communicative, out of politeness to others trying to help, if nothing else.
There are many websites that offer to translate a radio serial number into its code, so you might need to explore some of them. I quoted that website, simply because it has worked successfully by several of us in the past.
Renanek9
- x 4
I didn't mean to be rude. I just showed that this site can no longer fulfill this type of request. Only that.white exec wrote: 23 Jun 2021, 06:54 Sorry to have to say this, but you really do need to be a tad more communicative, out of politeness to others trying to help, if nothing else.
I was a little busy and just forgot to type "Thank you"
Sorry
Renanek9
- x 4
Update!
Need to left the radio with the double dash line. Within 1 hour the word "Code IN" appeared!
Thank you!
Thank you!
- x 6959
Ok, so better than waiting 30 hours and at least you know for future reference - enter the code slowly and surely to avoid a lockout - each time the code is entered wrongly, the time increases before you can try again.
Andreav6
Good morning everyone, I am a very happy owner of a 1998 Xantia TCT Actica.
Currently it has the original radio that when I bought the car did not work and was blocked "----" I will try to leave it under battery for 30 hours as indicated. Can anyone confirm the radio code for me? At the dealership they found "4515". The serial number of the PU-1561 A radio is 0023731.
In the meantime I bought an identical radio but without code whose serial number is 0019595. Can anyone calculate or tell me where to calculate the code?
Thank you very much
Thank you very much
