Rpo number
darrin
- x 3
Rpo number
I had a look at old post for rpo number but I did not understand
how do you get the rpo number for diagbox ? By the way citroen c3 1.4 hdi
wurlycorner
- x 271
Re: Rpo number
I don't believe that's the right sticker to find your RPO number.
It should be at least 5 digits long.
The four numbers below the VIN on that all look like vehicle weights to me.
- Gross vehicle weight
- Gross train weight
- Max axle load (Front)
- Max axle load (Rear)
Iain
CX DTR T2 Safari (silver)
Iain
PaulC5
- x 705
Re: Rpo number
Look at the label with the tyre pressures on. It should be the number at the top. It might also have been written in the service record booklet on the inside front page.
darrin
- x 3
Re: Rpo number
That's the only label I could find no label with tyre pressure on it it was on the door frame o the passenger side. I had a good look round the car. I will have a look at the paper work that came with the car thanks for all the replies
PaulC5
- x 705
Re: Rpo number
Open all the doors and look for the tyre pressure sticker, if it is still on the car it will be on one of the pillars, usually a front one or a middle one.
The vin can be used for the car build data which gives the rpo but I think at the moment the forum does not have access to Citroen's procedures/data due to changes being made, however, you should be able to get it from a Citroen dealer.
You have not given the year of your car but if you know its registration date you can use a rpo calculator to work back to get the rpo but knowing it will have been made before then.
darrin
- x 3
Re: Rpo number
Thanks pushed the car out of the garage and found the label on the inside door by the wheel arch thanks for the help I still could not get the diagbox to talk to the car even with the rpo number
- x 8431
Re: Rpo number
If Diagbox is not talking to the car Darrin, it may be because you have the wrong model chosen. I found this out with a C4 Grand Picasso the other day. A late Blue one. Blue as in HDi with AdBlue, not a car painted blue I should hasten to adddarrin wrote: 28 Mar 2025, 08:21 I still could not get the diagbox to talk to the car even with the rpo number
My initial attempts to connect as a C4 Picasso failed totally, even with VIN and RPO entered into Diagbox.
My connection attempt by declaring the car to be a C4 SpaceTourer (which it wasn't) was fully successful.
Worth a try perhaps to try all the C3 variants on offer in the Diagbox menu.
Usually, you know you have hit the jackpot as Diagbox should return the VIN as the first thing it does for you to confirm you're connected to the right car.
- x 1476
Re: Rpo number
But don't try selecting a really old model, as some have different pinouts and I have heard of an interface unit being fried.
Does diagbox detect that there is a vehicle detected at all?
It may be worth finding and checking the fuse that powers the diagnostic connector on the car.
darrin
- x 3
Re: Rpo number
Thanks I tried that it came up with the vin on the c3r model but that was all will try some more this weekend but not hopeful
PaulC5
- x 705
Re: Rpo number
On your tyre pressure sticker the rpo number looks to be 10851 which works out as a production date of 25 July 2006. http://www.citroen-ds-id.com/gen/Gen_Organr.html Does this tie up with the registration date since so far I have not seen anything in your posts ?
The paint colour is KMYD which is the blue colour.
darrin
- x 3
Re: Rpo number
Yep that's what I put in the diagbox
darrin
- x 3
Re: Rpo number
I have got the diagbox working but it is not recognising the ecu my ecu is SID806 and the closest is SID807
- x 1944
Re: Rpo number
When asked to choose, is there more screen available with other options if you scroll down?
