Engine warning light appears after turning a tight corner
Bobster66
Hello, I have a 2016 C3 Picasso Edition, 1560cc diesel, which currently has 31,495 miles on the clock. An "engine warning light" has just started to appear in the info window, this happens after the car has warmed up a bit and occurs after a sharp left or right turn - the warning message disappears on straightening up but I'm guessing that whatever the condition is it will deteriorate 'til the warning light stays on, can anyone shed any light on this and suggest what the fault, and a remedy, might be? Cheers
- x 1056
Re: Engine warning light appears after turning a tight corner
Unfortunately without having the fault codes read for at least a hint in the right direction any advice would just be total guesswork.
- x 2943
Check the oil level.
xsara92
- x 3
The engine on my 2005 1.6HDi Xsara Picasso holds back when rounding corners, at above 30mph or so. My garage thinks that the only possible cause can be the EGR valve sticking as it opens and closes.
PaulC5
- x 653
I would go to a different garage, this sounds a bit far fetched. You could use a diagnostic machine as you go round corners and see if the egr is doing anything.xsara92 wrote: 26 Mar 2025, 12:17 The engine on my 2005 1.6HDi Xsara Picasso holds back when rounding corners, at above 30mph or so. My garage thinks that the only possible cause can be the EGR valve sticking as it opens and closes.
