Oil Change AT Aisin AWF8G30, PSA ATN8, AXN8 and EAT8
DIY Enthusiast
x 13
Unread post by DIY Enthusiast »
I made a short video how to make a dynamic oil change applicable for automatic transmissions Aisin AWF8G30, PSA ATN8, AXN8 and EAT8.
For each change you will need 4 L of AW-2 type transmission oil.
There is no need to reset "Automatic gearbox oil wear counter" with Diagbox because on these transmissions oil live is not couted i.e. counter is always 0:
The video in youtube:
andyandjulie
x 18
Re: Oil Change AT Aisin AWF8G30, PSA ATN8, AXN8 and EAT8
Unread post by andyandjulie »
Thanks for that. Does this apply to the EAT6 in a 2017 DS5? I'm guessing that it is the same principle..
andyandjulie
x 18
Excellent video by the way..
DIY Enthusiast
x 13
andyandjulie wrote: 13 Oct 2024, 19:18 Thanks for that. Does this apply to the EAT6 in a 2017 DS5? I'm guessing that it is the same principle..
Yes, it is the same.
DIY Enthusiast
x 13
andyandjulie wrote: 13 Oct 2024, 19:19 Excellent video by the way..
Thanks!
guym91
New User
Unread post by guym91 »
Hi, I have been told inexplicably the DS7 auto gearbox is a sealed unit and should not be tampered with or need servicing for the lifetime of the vehicle this seems really strange to me coming from DSG boxes where maintenance is essential I cannot find anything online official from Aisin to show the correct service schedule does anyone have anything that can be presented to the dealer?
Thanks !
joksa1984
x 6
Unread post by joksa1984 »
Hello @DIY Enthusiast
Thanks for the video instruction. I am about to do the same on mine DS7.
One question thou..I see that Revanol oil you used is AW2 and PSA 16 350 560 80 compliant, which is ok, but the thing i was wandering is the fact that Revanol is extremely low viscosity oil, almost double than Total Fluidmatic DVI MV.. What are your thoughts now after some time from the change on how the gearbox is working, like smoother changes, etc., if any....
Asking because Total is hard or impossible to find in Serbia, and Revanol is available...
Thakns....
GiDrA
Unread post by GiDrA »
joksa1984 wrote: 26 Mar 2025, 08:26 Hello @DIY Enthusiast
Thakns....
Hello Joksa, I am also from Serbia, driving DS7 2.0 BlueHDi 180hp - ~130.000km on a clock.
Which service you will be performing transmission oil change?
Will it be just a “change” or flushing everything with specialized machine to exchange all oil?
I think I will do mine in “Servis menjaca Slavko” good opinion/scores it got from different people and Serbian community. They are actually flushing entire oil.
The odd thing is that they are proposing this oil as new/replacement one - Kroon SP matic 4036 oil. Specification Aisin Warner JWS 3324 / AW-1
I have asked them specifically, and they responded that I shouldn't worry and that this oil is appropriate for my transmission.
Question to all, should this be correct?
https://www.kroon-oil.com/en/sp-matic-4 ... tle-38861/
Dragoslav
GiDrA
Joksa, have you replied something? I have received an email notification but dont see your message, my massage is the last post in this thread still…
joksa1984
x 6
This oil is not as per psa specification. Its for older version of gearboxes. I cant see its even for any PSA group cars..
What you need is AW2 for your gearbox. One of those is RAVENOL ATF T-ULV Fluid which I have used…
I have done 2 manual oil changes, and will do one more in 5k km, as the oil was still not transparent redish..
friedrichwang
New User
Unread post by friedrichwang »
English
Summary:
1. Place vehicle on lift and ensure the vehicle is perfectly level.
2. Use transmission fluid meeting Aisin AW‑2 specification.
3. Unscrew the inner nut (oil‑level check nut) at the bottom. Once fluid stops draining, remove the outer nut to fully drain remaining fluid.
4. Reinstall the large nut, torque to approx. 30 Nm. Refit the small nut, do not fully tighten.
5. Open the transmission filler port on top. Pour in 4 L of specified transmission fluid, then secure the filler cap.
6. Engage parking brake fully and start the engine. Cycle repeatedly between R‑N‑D‑R within the following 5 minutes. Hold brake during each shift; release brake after gear engagement and hold for 10 seconds.
7 Shift lever back to Neutral (N).
8. Check transmission fluid temperature, keep it within 35‑63 °C.
9. Loosen the inner nut for fluid check‑drain (use a container for collection). Stop when fluid drips instead of flowing in a steady stream.
10. Reinstall and fully torque the inner nut. Procedure complete.
friedrichwang
New User
My understanding, the outer nut should be under 29 to 30Nm ,not 39Nm.
And the volvo's elec shifter auto transmission fluid(for AWF8G55) is also fit for PSA.
zipdip
x 4
Unread post by zipdip »
Just a thought has anybody removed the Aisin fluid from the filler hole on the top of the box,with a pump collect the fluid and measure what you remove and then refill
2009 C5 1.8 vtr+
