C5x7 3rd time steering leaking
aerodynamica
- x 215
Re: C5x7 3rd time steering leaking
Not sure matt, after what Stu said, I thought the rack sent was the wrong type but I measured the throw at 180mm so maybw it is right after all
Graeme M
PATaMAT
- x 12
this is wildaerodynamica wrote: 08 Mar 2025, 13:39 Hopefully there's not something I've missed because I've gone ahead and got medieval on the housing.
The block chopped off, 25mm hole now 30mm, a bit of a groove to the outside to help a rubber gaiter stay attached, a circlip groove cut in the new 30mm bore for a circlip that I don't have yet..
Pic shows it now and the metal ring now fitted back in.
i wonder if it will work for you
PATaMAT
- x 12
the bronze ring is the bearing
From the inside of the housing, the Simering is pressed in,
then the ring is pressed in - the bearing
everything is pressed with a tool to the required depth
if you leave out the bearing ring, it will be bad.
the shaft is inserted into the housing and it's done
moizeau
- x 429
Are the seals double lipped? If not they seem to be the wrong way round. The lip/spring side should be on the oily side. I realise they're not fitted yet and may just be placed for a photo but after the great work that you're doing it would be a bugger to say the least.
Pete
PATaMAT
- x 12
I think this seal is intended as a cover sleevemoizeau wrote: 09 Mar 2025, 09:05Are the seals double lipped? If not they seem to be the wrong way round. The lip/spring side should be on the oily side. I realise they're not fitted yet and may just be placed for a photo but after the great work that you're doing it would be a bugger to say the least.
The oil seal is under this
KennyW
- x 165
Graeme,
You have done a lot of work since my last post, well done. On my last rack I removed the lump and fitted a suspension rubber over the pinion.
I'll be interested in the final result. I've always thought about having a new pinion shaft turned out of good steel, but never costed it up.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
aerodynamica
- x 215
I'm glad you're saying that because I actually was going to put them in this way. The one that came out was that way and the ones I saw elsewhere were also that way round.moizeau wrote: 09 Mar 2025, 09:05Are the seals double lipped? If not they seem to be the wrong way round. The lip/spring side should be on the oily side. I realise they're not fitted yet and may just be placed for a photo but after the great work that you're doing it would be a bugger to say the least.
Incidentally the refurb rack only had 1 seal fitted and the top seal was missing. This had allowed the seal to drift upwards.
I think I'll turn the seal to the orientation you suggest
Graeme M
aerodynamica
- x 215
Got to try something !PATaMAT wrote: 09 Mar 2025, 08:34this is wildaerodynamica wrote: 08 Mar 2025, 13:39 Hopefully there's not something I've missed because I've gone ahead and got medieval on the housing.
i wonder if it will work for you![]()
Graeme M
aerodynamica
- x 215
Hi Kenny, it also crossed my mind but to make that I just think worud cost so much. Citroen couldn't be bothered so I doubt it would work out. I think I'll going to try and coat the exposed bit with a protective paint. I do wonder if the shaft has torsional effects that might cause the coating to crack though.KennyW wrote: 09 Mar 2025, 10:17 Graeme,
Kenny
Graeme M
aerodynamica
- x 215
I think so, the final fitting will take account. These are single lip oil seals and I hope the sleeve works well with them.PATaMAT wrote: 09 Mar 2025, 10:07I think this seal is intended as a cover sleevemoizeau wrote: 09 Mar 2025, 09:05Are the seals double lipped? If not they seem to be the wrong way round. The lip/spring side should be on the oily side. I realise they're not fitted yet and may just be placed for a photo but after the great work that you're doing it would be a bugger to say the least.
The oil seal is under this![]()
Incidentally, do you still have a C5 and has your original work from 2017 lasted?
Graeme M
- x 2343
Enjoying catching up with the progress
I'd not worry about that, if you can get any meaningful twist in a solid 20mm rod, even of the bloody awful steel grade Citroen managed to find for these, I'd be quite surprised!aerodynamica wrote: 09 Mar 2025, 12:05 I think I'll going to try and coat the exposed bit with a protective paint. I do wonder if the shaft has torsional effects that might cause the coating to crack though.
aerodynamica
- x 215
aerodynamica
- x 215
This week I'll take the parts into the workshops and refine it. I'm concerned that this refurbished rack is not the correct version I.e the pinion might have different teeth to those on the car so I'm not sure I'll do too much to clean up this shaft. I'll work on the shaft that will remove from the car.
This refurbished rack is 3 3/4 turns lock to lock. Although it measures 180mm travel. It makes me think the gearing is different. Unless it's a red herring and that the number of turns is reduced on the car because it's limited by something other that the rack stops? Doesn't seem likely
8x teeth on this pinion is 45° between them so surely the number of teeth on the rack governs it. Need to physically count them.
Other possible red herring is the 2x plastic end stops I found under the rack boots might not be the ones for a short rack. Possibly the shirt rack has an additional pair. Not sure. Kind of thinking out loud here
Graeme M
- x 2343
Well, you could end up with an LDS puddle, but we are starting at that point, so the only way is up!
Agree with your thinking aloud below, I'm sure it's controlled by the rack rather than the pinion. I think I'd be keen to get this done and fitted, if it becomes possible to "turn the wheels too far" I'd think it was perfectly "liveable" in that state. Repeated the job on the rack / pinion you take off could then be optional / done at your leisure.
aerodynamica
- x 215
Hi Matt, that was the plan but having carried out the work I found that the pinion valve/ shaft that has come off the car is identical to the one from The rack Stu sent. In fact the one fro. The car that is leaking is so badly damaged that it has deep scores that look difficult to fix.MattBLancs wrote: 10 Mar 2025, 08:18Well, you could end up with an LDS puddle, but we are starting at that point, so the only way is up!![]()
One on the left is the leaking one off the car. Ot has a groove worn in it. No wonder it was gushing out. It measured at something like 19.2mm at the worn part..
Graeme M
