Possible fuel filter issue
SectorOMEGA
Hello, Im trying to figure out a possible issue with fuel filter and loss of fuel pressure. I have code p2291 and just doing some visual checks when I saw that I have a leak from the fuel filter cap, specifically at the button that is used as pump(correct me if Im wrong about the pump). Is this normal or it should be dry.
- x 6955
Re: Possible fuel filter issue
You need to check the unions are on tight as there shouldn't be any leaks. Second make sure it's not from the water bleed screw (2):
Failing that it may need replacing. P2297 does include the Fuel Filter as a Suspect for this fault code:
| Fault Code: | P2291 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
SectorOMEGA
Brilliant as usual Marc! Thank you so much! Water Bleed was on the wrong side, fixed thanks to you, but now I have deeper problems and honestly don't know where to start.
As of now I have B1811 - Fault On The Diesel Fuel Additive Pump and I have checked the reservoir its type BVH2, it has fluid in it but still the error remains. Im trying to do a search if the reservoir is all in one pump and tank and from where to start troubleshooting
Also the car is in limp mode and the diagnostic(TopDon 900bt) shows 100% DPF and around 10mbar on idle.
