Broken Bosch VE pump fulcrum lever
kelyje
Unread post by kelyje »
Hi guys
while fitting the hydraulic head of my Peugeot 205 Bosch VE pump I broke the fulcrum lever.
The only spare ones I could find online available are of a different design and not sure if they would work. The black one with the hook is the one in my pump.
Does anyone have a spare one or know if this can be welded back on or if fitting a different one is possible?
As this is our only vehicle, fixing this is asap is very important to us, thanks for any help!
PaulC5
x 698
Re: Broken Bosch VE pump fulcrum lever
Unread post by PaulC5 »
kelyje
Thanks for the reply. Unfortunately they didn't have in stock the one I broke.
I had it welded, a German welder did a great job (German pump needs a German welder I reckoned), today finished assembling the pump, bled the air from injectors and it started beautifully?Did a test run round the village and it goes fine.
