Hi Guys
One of my touch-sensitive door handles is behaving erratically. Sometimes it works fine, then it won't work for a week. There's no rhyme nor reason to it. It's the drivers-side rear which unlocks all the doors.
I had heard that a BSI reset may fix it, but I'll probably stand corrected.
Please let me know if there's an easy fix..
Andy
DS5 door handle
- x 1464
Re: DS5 door handle
No harm in trying battery off, but it probably needs a new handle. If you can get a scanner on it you should be able to see what it is doing.
LeRoy KinCaid
- x 5
Re: DS5 door handle
I've had two go on passenger front door, one on passenger rear and one on driver's door, a reset didn't fix any of them and they've all been replaced and covered by extended warranty, apparently they cost about £6/700 each to supply and fit, including repainting.
Djandree
- x 38
andyandjulie
- x 15
Re: DS5 door handle
Thanks for the advice all. Like the diagram DJ, I will disconnect it and check the connectors when it stops raining..
andyandjulie
- x 15
Re: DS5 door handle
I've seen some keenly priced replacements on AliExpress, anybody tried one from there?
Djandree
- x 38
Re: DS5 door handle
Well. Some people at other forums saying that they are ok, some don't. Well up to you to check it)))
andyandjulie
- x 15
Re: DS5 door handle
I've found one on Aliexpress:
https://www.aliexpress.com/item/1005002 ... nav-review
40 GBP.. And it's black! I've checked through their message centre and they confirm it fits my VIN No.
Anybody got any experience of this particular part?
Djandree
- x 38
Re: DS5 door handle
Not much though, worth trying
