Lexia Connection Problem Help
sydo
x 9
Unread post by sydo »
Hello everyone, regards friends, I am having a connection problem with my Lexia device, the computer sees the device, it sees it in the Diagbox program, when I try to connect, it reads and recognizes the VIN number but it does not connect, it gives a warning as seen in the picture.
sydo
x 9
Re: Lexia Connection Problem Help
Isn't there a friend who can help me?
Kees
x 144
Unread post by Kees »
If you have an illegal version (AliExpress), don't try to login, put the internet connection off.
sydo
x 9
Kees wrote: 26 Feb 2025, 18:24 If you have an illegal version (AliExpress), don't try to login, put the internet connection off.
Yes, I bought it from aliexpress. But when I try to connect, I don't have an internet connection, but it still doesn't connect, it reads the VIN code but doesn't proceed any further and gives the warning seen in the picture.
Mihael_M
x 36
Unread post by Mihael_M »
You did not specify the version of the Diagbox. Otherwise, during each installation, the Interface Checker program is also installed in addition to the Diagbox. With this program, you can test the probe.
sydo
x 9
Mihael_M wrote: 27 Feb 2025, 16:58 You did not specify the version of the Diagbox. Otherwise, during each installation, the Interface Checker program is also installed in addition to the Diagbox. With this program, you can test the probe.
diagbox version 9.85, but I tried it in other diagbox versions, still the same problem,
sydo
x 9
By the way, when reading the VIN number, the relay sound is heard, after reading the VIN number, it does not proceed any further.
Kees
x 144
You can also try to put the vin number manual instead of scanning
sydo
x 9
Kees wrote: 27 Feb 2025, 17:51 You can also try to put the vin number manual instead of scanning
I even tried connecting by selecting the VIN number and vehicle model but unfortunately it doesn't work, I don't think the problem is due to the way I connect.
x 3281
Just a thought (and I am NOT saying this is the cause of your problem), but have you checked the fuse that 'manages' the diagnostic port? These can fail, and once it has you cannot connect to the ECUs until it is replaced. I do not know which fuse it is; you will have to check the owners' manual.
sydo
x 9
Hell Razor5543 wrote: 27 Feb 2025, 18:49 Just a thought (and I am NOT saying this is the cause of your problem), but have you checked the fuse that 'manages' the diagnostic port? These can fail, and once it has you cannot connect to the ECUs until it is replaced. I do not know which fuse it is; you will have to check the owners' manual.
How can I find out which insurance you mentioned?
Mihael_M
x 36
I also use 9.85. If your Diagbox can read the VIN, then the OBD port is correct.
Have you tried to start the interface checker? It is essential that the rest can work.
sydo
x 9
Mihael_M wrote: 28 Feb 2025, 15:20 I also use 9.85. If your Diagbox can read the VIN, then the OBD port is correct.
When I connect my Lexia device with psa interface checker v3, it does not see any problems and even updates it. Currently, Lexia version is 4.3.7
Mihael_M
x 36
It seems that Lexia and Obd port are fine. I would try another version or even the same 9.85 but from a different source.
sydo
x 9
Mihael_M wrote: 28 Feb 2025, 19:15 It seems that Lexia and Obd port are fine. I would try another version or even the same 9.85 but from a different source.
Tried on 9.85 and other versions and on other computers and different devices, the result is the same, it does not connect.
