Can you solve this one?
wrinklet1
Unread post by wrinklet1 »
Its not an earth problem........
wrinklet1
no fan seizure
wrinklet1
the ignition switch is okay
Dave Burns
Unread post by Dave Burns »
Glow relay ?
Dave
wrinklet1
Nope, not the glow plug relay.
<u><i><b>CLUE</b></i></u>
Its something that you wouldn't expect and something a mechanic could easily rip you off with.
FrenchLeave
Unread post by FrenchLeave »
Some people do sudoku, others solve obscure electrical problems on Xantias.
stewart_c
Unread post by stewart_c »
Don't compare citroens with suduko :- at leasr suduku is LOGICAL
mpr1956
Unread post by mpr1956 »
I'll have a go... Was it the fast idle cable outer insulation failed, causing the cable to short circuit against the injector pipe ?
wrinklet1
MPR1956, Good answer, but no where near.
wrinklet1
Stewart C, there is a logical answer to this one
vanny
Unread post by vanny »
did the condensor on the ice cream maker fail causing a mass amount of Mr Whippy to be sent into the electrics causing shorts left right and centre?
BrianM
Unread post by BrianM »
Fuse connections ?
fastandfurryous
x 4
Unread post by fastandfurryous »
Loose ECU multi-way connector?
in fact, was it a loose *anything* connector?
dnsey
x 19
Unread post by dnsey »
Something to do with the ignition switch? Dodgy switch 'nudged' by indicator stalk?
x 1240
Unread post by Peter.N. »
Well, tell us then!!
