Can you solve this one?
wrinklet1
Unread post by wrinklet1 »
Driving my Xantia Td, and all is well, THEN, the radio switches off, the ABS light lights up, the rev counter jumps when the indicator is swithed on..Why??? [}:)]
I have solved it [^] and really it could have cost £100's if I had gone to Citroen.
Can you solve it??
Paul.
mrbump
Unread post by mrbump »
broken earth for wing mounted flasher?
j_roc
Unread post by j_roc »
Sound's as mentioned - a dodgy earth. Like when you press the brake pedal with the indicators on the brake light dimms - another earth problem.
wrinklet1
nope, nothing to do with the wing indicator. Nothing to do with the brake pedal either.
Paul
Stinkwheel
Unread post by Stinkwheel »
Battery Failure?
wrinklet1
Nope, the battery wasn't the problem either
Stinkwheel
OK so its gotta be something slight left of centre, i.e. its electrical in nature but maybe not caused directly by electrical item? No, probably not that sounds silly having read it back.
Its got to be a voltage drop thing, ABS light, radio turn off, rev counter etc all point to a voltage drop below the operating range.
could grasp at straws all night? Starter ? Short in fuses box due to water ??????? Give us a clue.
wrinklet1
Well, its not the starter, or fuses, not even water getting in. It is electrical though
x 1238
Unread post by Peter.N. »
Intermittent/high resistance in batt + supply line?
wrinklet1
nope the battery supply is fine
Stinkwheel
Did the fan seize up and voltage drop when it tried to turn?
fastandfurryous
x 4
Duff ignition switch?
j_roc
What the hell is it?
mrbump
does the indicator CAUSE these problems, or are these all symptoms of the prob? Is it that the rev counter jumps when the indicator is on WHEN the prob is already apparent?
if its the latter, i'll go for either a strange short accross something that could possibly invert the voltage that gets heated up, stop soleonid possibly?
Or missing earth wire to gb?
Or ....?
mrbump
in fact i'll go for missing gb earth.
