C5 After Market Android - No sounds at the rear.
sonny7
Unread post by sonny7 »
Guys I need help, I'm getting cuckoo over here 😵?💫🤯
I'm posting this question here because I've looked everywhere and can't find the solution.
So I've installed a Chinese brand Android aftermarket multimedia system "Junsun" and it works pretty well except for the sound..
The sound is absolutely terrible and above all I have no sound at the rear speakers, and I don't understand why?
I've tried a lot of so called solutions I found online but I can't get it work... 🙁
Logically I have an amp because I have the Hi-Fi pack but I'm going to check this weekend in the glove compartment, just to make sure.
Could someone give me the solution because I can't figure out if the sound is coming out of my amp or not and if not, how to connect it and therefore if it's possible?
Many thanks for your help 🙏
Kees
x 144
Re: C5 After Market Android - No sounds at the rear.
Unread post by Kees »
This is the reason, because you have an Amp. This means the hole system works different.
Greeting,
Kees.
x 6958
That's something you will need to take up with the aftermarket supplier - we don't support after-market units because of compatibility issues or the additional requirements they may need to function correctly with the factory system /vehicle.
x 1044
Unread post by wheeler »
When i upgraded to an android unit when doing research i notice that for my model there was listings for 'CAN bus' versions & non CAN bus. My car model is only available with CAN bus but when i looked further into it, it seems like that is Chinglish for Factory amp or no factory amp.
Sounds to me like you need a different adapter harness that is compatible with the factory HiFi amp.
Back in the day when i used to fit a lot of phone handsfree kits you normally needed a different adapter if the car had Bose, H/K sound system etc.
sonny7
Kees wrote: 21 Feb 2025, 10:16 This is the reason, because you have an Amp. This means the hole system works different.
Greeting,
Kees.
what do you mean?
so what? I should remove the Amp then?
GiveMeABreak wrote: 21 Feb 2025, 10:57 That's something you will need to take up with the aftermarket supplier - we don't support after-market units because of compatibility issues or the additional requirements they may need to function correctly with the factory system /vehicle.
They are absolutely useless, they have no idea about what I'm talking about.
3 months I have been asking the same questions with no answer...
wheeler wrote: 21 Feb 2025, 22:32 Sounds to me like you need a different adapter harness that is compatible with the factory HiFi amp.
By harness you mean the quadlock ISO connector?
I saw that it was car brand related and not speakers' brand related, like this one:
https://camaudiotech.com/product/ct20ct ... o-adapter/
all of that is so confusing.. :|
x 1044
Do you have a link to the unit you have bought?
Removing the amp wont make a difference as its to do with the way its wired.
sonny7
Here is the link:
Junsun V1 Plus Car Radio For Citroen C5 2008 - 2017 wireless CarPlay Android Auto car intelligent systems No 2 din 2din DVD
https://a.aliexpress.com/_Ewk5cay
Bought the V1 Pro 6gb - 128gb
Does it help?
x 1044
Was this not on the listing when you bought it??
Kees
x 144
Here you can see the reason.
With an amplifier there are only 4 wires come from the radio and being multiplex by the amplifier.
When you have only a radio then there are 8 wires for 4 speakers.
Greeting,
Kees.
sonny7
wheeler wrote: 23 Feb 2025, 10:02 Was this not on the listing when you bought it??
yeah I also noticed that but these idiots didn't specify this when I bought the unit, they only added this recently... 🤬
now it explains why I have the problem..
what can I do now?
change the amp?
x 1044
So if that diagram is correct you could disconnect & bypass the amp by linking the speaker wires direct. That's pretty much all the adapter harnesses you get do, they just bypass the amp.
sonny7
Kees wrote: 23 Feb 2025, 12:32 Image
Greeting,
Kees.
I think I understand the explanation (kind of) but sadly the schematics don't make any sense to me 😕
sonny7
wheeler wrote: 23 Feb 2025, 13:35 So if that diagram is correct you could disconnect & bypass the amp by linking the speaker wires direct. That's pretty much all the adapter harnesses you get do, they just bypass the amp.
yeah so by bypass you mean connect another aftermarket amp, even a basic cheap one and that should do it?
Kees
x 144
You can also first try to disable the multiplex option in the diadbox on/off.
It's in the part amplifier yes/no.
Greeting,
Kees.
