Change language RT3
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
Boz2010
Re: Change language RT3
Unread post by Boz2010 »
I have 2006 407 SW Rt3 CAN firmware 6.63. Can you send me ISO file link please.
Thank you for your help and time
x 6948
Guys - I'll look at this Monday for you both ^
edvaing
Unread post by edvaing »
Hi,
Would appreciate any assistance in updating the firmware software on my C6.
Current settings is:
Steuergerate-Nr 966329 1577
Display-Nr. 966332 1780
Soft-Version Steuerg 6.62
Soft-Version Display C30CD2C35
Need to change the language settings from German to English.
regards,
Inge
x 6948
edvaing wrote: 12 Feb 2025, 11:32 Hi,
regards,
Inge
Inge, please check your private messages. However as a new user, you may need to post a few more times before you can use the provate messaging system, so I suggest putting a post in the Introductions section if this is the case:
Introductions
Sonny
Unread post by Sonny »
Hello,
I have Fiat Ulysse year 2004, with Tedesco menu, unfortunately I dont understand Tedesco. When I try to change a language it is asking me for a configuration CD. Can you please help me with that?
Thank you :)
x 6948
@Sonny: You have a 'VAN' protocol network version so require a different firmware. I have a later firmware for PSA vehicles, which should work with this vehicle, but it will probably require the system firmware to be updated first of all as this is an early firmware version. Check your Private Messages.
Sonny
Thank you very much Marc, I'll download the file and try to do it
I'll let you know thank you very much
Sorry for my English but I use Google translator because only Italian
Greetings Sonny
Viddack
Unread post by Viddack »
Hello,
can anyone help me in order to update my multimedia and to change language from French to English.
I have Peugeot 407 2.0 HDi, I am providing details of the multimedia.
katijuli
Unread post by katijuli »
Hello, I need a firmware update CD for my Peugeot 307cc 130kW 2004, could you please help.
katijuli
katijuli wrote: 18 Mar 2025, 18:41 Hello, I need a firmware update CD for my Peugeot 307cc 130kW 2004, could you please help.
x 6948
@katijuli
Check your private messages.
unsaloc
Unread post by unsaloc »
Hello, last week I became the owner of a 2005 model Peugeot 807 2.0 benzin AT. Can you help me change the language to English?
x 6948
unsaloc
The operation was successful, thank you very much. =D> [-o<
Boz2010
I have 2006 Peugeot 407 sw 2.0 AT
RT3 CAN 6.63 can you please send me a link for CD so I can change language to English.
Thank you in advance, Haris.
