DS7 driver side DRL intermittent flickering
BenDS7
Unread post by BenDS7 »
My driver side DRL is flickering, hoping it is just a connection issue but I have noticed there is condensation in both of them but really don't want to have to deal with the dealer as they are awful, I have extended warranty but not sure if they would be covered. Can anyone advise the easiest way to check the connection, I do also have an obd reader would it be worth plugging this in?
Djandree
x 38
Re: DS7 driver side DRL intermittent flickering
Unread post by Djandree »
Hello. It might be a connector but it might be as well broken electronic unit look here for some answers
viewtopic.php?t=74191
BenDS7
Thanks for the reply. Any idea if water ingress causing DRL failure would be something that is covered under the Das approved extended warranty?
Djandree
x 38
It should be, but you have to check
x 6963
They have certain tests and guidelines for warranty replacement and was the same for the rear light clusters that filled up with water. On the rears for example they measured the level of water and if above a certain amount they replaced them. With a DRL, there's generally little area to fill, so I would expect a replacement if it's more than condensation (that they will say will evaporate in use).
