DPF
Vaszax
DPF
Hi. I have a 2010 C4 PICASSO 1.6 HDI with 155.000 km on the clock and i think that the dpf filter regenerates too often. Is it likely to be full ( no engine light on the dash or any message)? Would you suggest to clean it or replace it? Could you recommend any good aftermarket brands of dpf's? Thanks in advance!
Vaszax
Re: DPF
I think it regenerates at about 500 km. I do mostly short journeys 20 km to go - 20 to come from work every day and 4-5 into the town. I can understand it as the engine work more rough and the mirrors are heating up during regeneration. My mechanic told me to go on s long trip so the dpf to clean properly.
- x 1499
Re: DPF
Sounds about right for short journeys. A decent long run to get it properly hot might help, but I had a 307 that ran a little bit rough during regen - never caused any issues (aside from being noticeable!).
Mihael_M
- x 37
Re: DPF
Before replacement or any work, the DPF should be diagnosed. ELM 327 with the FAP Lite APK program can be used for that.
https://www.aliexpress.com/item/1005006 ... 1802Ac6j5z
https://faplite.en.aptoide.com/app
There is also a more complex Lexia 3 diagnostic, for starters this simpler and cheaper one is enough.
If there are no warnings, then everything is still fine.
